problem lcd,core-opl3
I have finish opl3, the Core, lcd, but on lcd the problems. opl3 light is off.
Can you help me?
Thanks!!!
the photos------------>
first photo switch on,second photo after 5-6 seconds…
3 photo core and 4 photo opl3…
…and now?
I guess this would be a wiring error. The OPL and LCD share a data buss, and perhaps they are talking at the same time.
I would first check all connections against the schematics with a multimeter. I’d also consider soldering the components into the PCB properly, rather than leaving hem floating like that - it leaves room for short circuits. Similarly, it’s worth investing in connectors for the cables, rather than soldering them onto the jumpers.
Thi programme also broadcast in Italian: Midibox fm problemi vari…
Yes, seems to be a connection issue. “READY.” indicates, that you haven’t uploaded an application yet, MIOS itself only writes READY a single time, thereafter no LCD transfer will take place anymore.
But you reported, that you notice still changes (more black bars) - therefore a typical connection issue
