pretty big midi-box NG
Hi there,
I’m thinking of building a pretty sick midi-baby with 24xMF 48xencoder 48xledring 96xbutton and some “normal controls”.
I thought this could be done with:
3x18F running MIOS
each core running 8xMF 16xencoder 16xledring 32xbutton+led 2x 40x2 LCD  ;D
And one core for a graphical LCD and the transport controls etc.
Is this at all possible?
If I understand it right this coiuld be accoumplished with the use of the MIDI-link to link the cores togheter.
I think I might have to use 2 MIDI llinks (or COM links) to the host PC in order to process the VU-meter data etc.
I know it’s only a lazy design picture but I’m actualy planning on building this baby.
Thanks in advance guys!
now that is beast!!
and from what i’ve heard/read so far it seem perfectly doable - good luck!
I think also u may even soon be able to have one main LCD that addresses all cores in the ‘chain’…
Best
Dan
I planning on using a graphical at the end, and 2 (or probably one initialy due to the costs) 2x40 LCD’s on each core so you can see what you are doing on each channel.
So you can use 1 encoder to select function (balance,AUX,bass,treble, etc) And one to select the value.
I would then have something like this:
[table][tr][td]PAN 1[/td][td]BASS2[/td][td]AUX3[/td][td]TREB4[/td][/tr]
[tr][td]L35[/td][td]+5db[/td][td]-20db[/td][td]+2.5db[/td][/tr][/table]
Greetz tHe_IkkE
P.S.: I forgot to put an LED-digit MTC display on the right
How I can  to  receive  /whats hardware  resourse is  need/ a configuration with:
•      16 motorfader+1 masterfader,
•       8 encoder+8 LED rings, +1 encoder      Jog/Shuttle for the transport control /btw. whether perhaps  to use  jog/shuttle encoder  ALPS  SRGP Series,10 pulses?/.
•      5 button for Play/Stop/Record/FF/RW,
•      64-128 assigned buttons+64-128 LED indications for this buttons?
•      240x128 LCD
BR Albert >
•      240x128 LCD
three core modules, some DINx and DOUTx modules and software skills (or somebody who helps you to customize this controller…)
Now Now,
 stop giving Thorsten Ideas! or he will run out of space again!  ::slight_smile:
