power supply ma rating for fully equipped MBSEQ 3.2
Will the 9v 500 ma suggested power supply still be enough for the MBSEQ 3.2 with all the extra buttons and leds along with at least 2 IIC modules, 8 banksticks and both LCDs? Would it fall under 500ma or go above?
if your LCD are not backlighted it should be sufficient…
The lcds are backlit! Should I get a new power supply with a higher ma rating before trying to connect all the buttons and encoders? I just have both lcds and the core powered up right now and it works like a charm. What ma rating would you recommend? I read somewhere that as long as you stay under 1 amp you’ll be ok? Is this true?
