hay guys
checked around for more than 2 hours (no info found)
about possibility to drive a 6-8 rows lcd display
with midibox hardware
please somebody have some info about ?
thanks
Z.
hay guys
thanks
Z.
Compatibility mostly depends on the LCD driver. Could you please provide a datasheet about the display you would like to connect?
You can always use a GLCD. A 128x64 can display quite a few rows depending on the font you use (small 3x5 font, 2 pixel row spacing = 9 rows or the “regular” 5x7 font with 2 pixel row spacing = 7 rows).
something like this
http://www.futurlec.com/LED/LCD128X64.shtml
or this
http://www.futurlec.com/LED/BLUE128X64LCD.shtml
Z.
The first one you linked has a T6963C controller. Now you need to figure out if it’s supported by MIOS yet. Go to ucapps.de and check under “LCD module”.
The first one you linked has a KS0108B controller. Now you need to figure out if it’s supported by MIOS yet. Go to ucapps.de and check under “LCD module”.
thanks “nils” …
i’m checking tons of pages about midibox …
(unfortunately not so fast …)
my “target” is verify if is possible make a midibox as remote synth programmer" control
with much parameters as possible showed in more then 1 lcd display (like “ma-ckie” c4 control)
z.
