the most simple way to find this would be to change the MIOS32 environment variables before compiling any application (such as apps/templates/app_skeleton)
So, instead of:
export MIOS32_FAMILY=STM32F10x
export MIOS32_PROCESSOR=STM32F103RE
export MIOS32_BOARD=MBHP_CORE_STM32[/code]
you would write:
[code]export MIOS32\_FAMILY=MYFAMILY
export MIOS32\_PROCESSOR=MYPROCESSOR
export MIOS32\_BOARD=MYBOARD
All source codes and Makefiles which are checking/referencing to these values will print out an error message (sometimes very verbose since they are generated with #error)
This simple check also gives you the files locations or directories where something has to be changed, resp. where a new directory with similar files has to be created.
E.g., usually MIOS32 based applications don’t refer to any driver functions under drivers/$MIOS32_FAMILY - this is only done under mios32/$MIOS32_FAMILY (the HW adaption layer, take the files in the mios32/STM32F10x directory as a reference), the programming_model/traditional (which will need some #ifdef statements for your environment)
Means: probably you don’t need to refer any “driver” functions at all if your SoC doesn’t support such a library. Instead you would have to configure/access peripheral functions directly in the MIOS32 HW adaption layer
