Hello,
Propably this idea is just too complex to implement, but i´ll ask anyhow… Sorry, can´t help it. MBSid is a fascination and i think about it all the time…
Any chance to output CS_MENU_GetScaledParam through the dout chain in any form?
I am designing my own cs with some dedicated extra encoders i managed to implement (for Aout, envelopes, 8 menu encoders).
I am using a 40*2 display.
I really like the menu structure, but for editing a synth with many knobs it is nice if you don´t have to look at the display.
Also it would be possible to adjust menu order and cursor offset so that, for example, if you tweak the envelope encoders the display will flip to the env screen but show different parameters than those assigned to the env encoders, ready to be tweaked as well with the menu encoders.
For this some kind of visual feedback of the tweaked parameter would be great.
The 20*4 display option shows a bargraph on the lower line. I looked at the code in the cs_menu.inc and i see there are quite a few steps going on to get a value and print it.
Do you see any chance to output this value in any form over the dout chain?
Driving a BCD display or a LED bar comes to mind (many pins).
If i undestand the basics a BCD value can be transformed to a analog voltage with a resistor ladder. So even a LM3914 driven LED bar would be an option. I certainly wouldn´t mind the extra soldering.
