OLRE16 - Gallery Album
Album by Antichambre
OLRE16 in note mode.
Use Black(off) and white colors, keyboard like.
Drilling ring and oled window in PMMA
to delete
[Image not found: olre16-001.jpeg]
to delete
Naked OLRE16
It’s the first proto then only 2 rings/oleds and encoders. Before that I was not sure it will work then only few parts wasted if not.
But it's working and it was enough for testing!
OLRE16, in colors.
First ring is gradation from green to red with its step index in white
Second blue to red, step index off
OLRE16 with Lattice CPLD as Clocking/Addressing interface
Now with its 512 RGB leds /emoticons/grin.gif" title=“:grin:”>
OLRE16, saturated hue sweep.
Re: Drilling ring and oled window in PMMA
wow. thats stunning!
Re: OLRE16, in colors.
It looks really great!
I removed led rings from my design because I though it was almost impossible for me to fit them in 1.1in channel strip and looks good. But it seems you managed to do it?
Yes no 3d, no fake lol
It was not easy. The difficulty was to route the rings. it's 16 rgb leds with 32:1 multiplexing, 2 mux adress by ring.then it's a 48 channels bus which passes thru the rings on full length of the board. This top board is 4 layers but even with that, it was hard work.
Wow, looks amazing!
Oh yeah, looks so good !
Great work, I really hope there will be a way to get our hands on these. I’d love a few strips of this!
Re: OLRE16 with Lattice CPLD as Clocking/Addressing interface
Très chic!
Looking great!
Thank you! /emoticons/blush.gif" title=“:blush:”>
Some explanation:
Here I test the Logic Clocking/Addressing for 32*16 multiplexing around the TLC5958. With all the leds this time.
Previously I first tried to code this multiplexing circuit directly with the STM32F4 but it was too much process for a very bad result.
Then I designed an external logic circuit for that purpose, it was working but a was very complex circuit.
And finally I reduce this big logic circuit to one unique programmable logic ic, the Lattice CPLD.
Here I used an LC4256V evaluation board from Lattice. It's a TQFP100 with 256 macrocells and this is too much for that purpose.
So I make the VHDL program very small to fit in a LV4064(64 macrocells) which exists in a small TQFP44 package.
The components on the breadboard are just for 3.3V to 5V level shifting.
Voilà!
Interesting topic! Though it’s a little bit difficult to follow the discussions taking place as comments in the image section of the forum. Why don’t you just create a thread describing the project and put/link your images there?
Man, it looks awesome! Very well done! :slight_smile:
Many greets,
Peter
	Just now, ilmenator said:
		Interesting topic! Though it's a little bit difficult to follow the discussions taking place as comments in the image section of the forum. Why don't you just create a thread describing the project and put/link your images there?
Don't worry, I will do it. For you to know that the [dokuwiki](http://www.midibox.org/dokuwiki/doku.php?id=mb_olre16) already exists even if I have to update it also.
Re: to delete
yeah!!! i want that
Epic! Must be quite zen soldering all of those LEDs…!
	19 minutes ago, latigid on said:
		Epic! Must be quite zen soldering all of those LEDs...!
I still do a magnesium cure a few days before /emoticons/rolleyes.gif" title=":rolleyes:">
With the right method it’s about 6 hours to solder and test those 512 rgb leds…
magnificent!
Dear /profile/7584-antichambre/">@Antichambre,
This looks spectacular! And especially cool, since I was looking to build such a solution myself - without the OLED (but I'm quite the beginner at this so I'm at a far earlier stage).
Couple of questions - if you would be wiling to answer them:
	Which rotary encoder do you use? A standard "24 PPM" one with quadratic encoding? The reason I'm asking is that I was looking for a higher resolution solution, but that is hard to find (endless pot or hall-effect sensor was what I was thinking of)
	What is the exact part number of the LEDs you used? I had a certain bright LED in mind, but if you use a cheaper less bright one, that might suffice (judging by the video)
	Did you solder the LEDs on yourself? Reflow?
	Is there an update to your project site?
	Would you be willing to share schematics in a downloadable format? I'm sorry if this is considered rude (if it was not meant to be open source) - just don't know what your stance is on this.
Thanks for any info you might be willing to share!
It’s PEC16-4015F-S0024 . some more information in the dokuwiki…
	Yes it's better in real, always difficult to take picture of RGB stuff with an iPhone ;) Brightness is enough for my taste even with the plastic mask and window, the window is made with special pmma,
	led were ordered form china, i can share contact, here the [datasheet ](https://www.dropbox.com/s/2kruw6x5xfxtg3b/HQ19-2331BGRC.pdf?dl=1)
	Yes I did it manually, it's an ant work.
	No update for the moment.
	No schematic shared for the moment too! ;)
	Best regards
	bruno
Thanks for the quick response - especially after the thread is ‘on life support’ (not yet a zombie :wink:
The LEDs are indeed super bright (~250 - 1000 mcd for the various colours). However, in the setup how I would like to design it, I would use only 4 multiplexed channels instead of your 32, so they would be approx. 8x as bright. Did I deduce that correctly? (I assume the duty cycle of each LED is 1/32 at the most because of multiplexing - or do I misinterpret they way your setup works?). That would mean that I can use LEDs that are 8x less bright than yours to achieve the same physical brightness (while the max duty cycle would be 1/4 in my case).
The PMMA mask is very cool! Did you create these yourselves? If so, with which method? (3d printing, molding, etc.). Again - only if you would divulge this information!
In total - I would be very proud of myself if - at some point in the future - I would be able to achieve something remotely as cool as what you did :)
Thanks again for taking the time to answer my questions!
