NonMB SidSynth...
Hi everyone: before starting the whole project of building a midiBox sid synth, Im trying to build a simplier synth by my own. Im using a PIC16F873 microcolntroller to interfase my Sid Chip with my PC via serial port.
Using portB for data, portA for addres and portC for clock and cs/ rw signals, I run a max/MSP patch to control the sidChip/.
Well… the hardware seems to work but there is no sound yet and I was wandering if its there any kind of “brute force” test to be sure if my sidChip is alive.
I look around but I cant find anything. Any though will be great !.
than you very much !
diex
Hi Diex,
the easiest way is to use following register settings:
volume register: 0x0f  — you should hear additional background noise now!
frequency register (low/high) of voice 1 = 16777 (for 1kHz)
Sustain/Release = 0xf0
Attack/Decay = 0x00
Waveform = 0x11  (Triangle, Gate on)
You haven’t listed the reset signal of the SID - how is it controlled? Maybe it’s permanently active?
