grrrr…frustrating. thanks for the input, goyousalukis. here’s what i was able to find out:
i’ve checked and checked, but i still can’t find any connection problems. of course, there were those times when i would say “aha! there’s the problem!” and then i would check 3 times more and realize that my eyes had deceived me. sigh…but that’s beside the point.
the voltages on the core look good (all 5 volts). i used the pin to pin checks included on the core page. however, the voltages on the sid (when connected to the core), the voltages were 3V instead of 5V in all cases. the chips and lcd were removed for these tests. any thoughts, anybody?
trying to send sysex commands to the core with no luck. all i get is a series of random midi events every few seconds. at least it’s speaking… however, i get no sysex request(s), etc. keep in mind that the bare sid circuit (no chips) is connected. please don’t make me cut anymore wires… the software/connection is set up 100% perfectly and i’ve tried every bit of help on the midi troubleshooting page, but no luck. (loopback works)
here’s a little excerpt of the stuff that the input monitor spits out when i turn on my box:
TIMESTAMP IN PORT STATUS DATA1 DATA2 CHAN NOTE EVENT
000042F7 1 – FE – – – — Active Sensing
000042F7 1 – C0 00 – 1 — PC: Acc. Grand Piano
000042F8 1 – C0 01 – 1 — PC: Brite Acc. Piano
00004305 1 – FE – – – — Active Sensing
00004308 1 – FE – – – — Active Sensing
00004308 1 – C0 00 – 1 — PC: Acc. Grand Piano
00004309 1 – C0 01 – 1 — PC: Brite Acc. Piano
00004311 1 – FE – – – — Active Sensing
00004314 1 – FE – – – — Active Sensing
00004314 1 – C0 00 – 1 — PC: Acc. Grand Piano
00004315 1 – C0 01 – 1 — PC: Brite Acc. Piano
00004316 1 – FE – – – — Active Sensing
00004317 1 – C0 00 – 1 — PC: Acc. Grand Piano
00004317 1 – C0 01 – 1 — PC: Brite Acc. Piano
00004319 1 – FE – – – — Active Sensing
00004319 1 – C0 00 – 1 — PC: Acc. Grand Piano
0000431A 1 – C0 01 – 1 — PC: Brite Acc. Piano
00004323 1 – FE – – – — Active Sensing
00004323 1 – C0 00 – 1 — PC: Acc. Grand Piano
00004324 1 – C0 01 – 1 — PC: Brite Acc. Piano
00004325 1 – FE – – – — Active Sensing
00004325 1 – C0 00 – 1 — PC: Acc. Grand Piano
00004326 1 – C0 01 – 1 — PC: Brite Acc. Piano
00004328 1 – FE – – – — Active Sensing
00004328 1 – C0 00 – 1 — PC: Acc. Grand Piano
00004329 1 – C0 01 – 1 — PC: Brite Acc. Piano
0000432A 1 – FE – – – — Active Sensing
0000432F 1 – FE – – – — Active Sensing
00004331 1 – FE – – – — Active Sensing
00004332 1 – C0 00 – 1 — PC: Acc. Grand Piano
00004332 1 – C0 01 – 1 — PC: Brite Acc. Piano
and it (the first series) ends like this…
0000465B 1 – E0 00 01 1 — Pitch Bend
0000465C 1 – E0 01 03 1 — Pitch Bend
0000465D 1 – E0 00 00 1 — Pitch Bend
0000465F 1 – FE – – – — Active Sensing
0000465F 1 – E0 01 03 1 — Pitch Bend
00004660 1 – E0 03 00 1 — Pitch Bend
00004660 1 – E0 00 00 1 — Pitch Bend
00004662 1 – FF – – – — System Reset
0000466B 1 – E0 2C 03 1 — Pitch Bend
0000466D 1 – E0 00 00 1 — Pitch Bend
0000466E 1 – FE – – – — Active Sensing
0000466E 1 – E0 01 03 1 — Pitch Bend
0000466F 1 – E0 03 00 1 — Pitch Bend
00004670 1 – E0 00 00 1 — Pitch Bend
0000467D 1 – FE – – – — Active Sensing
0000467D 1 – E0 00 01 1 — Pitch Bend
0000467E 1 – E0 03 03 1 — Pitch Bend
0000467F 1 – E0 00 00 1 — Pitch Bend
00004680 1 – FE – – – — Active Sensing
00004680 1 – E0 03 48 1 — Pitch Bend
0000468E 1 – E0 03 00 1 — Pitch Bend
0000468E 1 – E0 00 00 1 — Pitch Bend
0000468F 1 – FE – – – — Active Sensing
00004690 1 – E0 01 03 1 — Pitch Bend
00004691 1 – E0 03 00 1 — Pitch Bend
0000469F 1 – FE – – – — Active Sensing
0000469E 1 – C0 01 – 1 — PC: Brite Acc. Piano
0000469F 1 – C0 03 – 1 — PC: Honky-Tonk Piano
000046A0 1 – C0 03 – 1 — PC: Honky-Tonk Piano
000046A0 1 – E0 00 00 1 — Pitch Bend
000046AF 1 – E0 1A 03 1 — Pitch Bend
000046B0 1 – E0 00 00 1 — Pitch Bend
000046B1 1 – FE – – – — Active Sensing
000046B1 1 – FF – – – — System Reset
000046B2 1 – FF – – – — System Reset
000046B2 1 – C0 00 – 1 — PC: Acc. Grand Piano
000046C0 1 – C0 00 – 1 — PC: Acc. Grand Piano
i randomly tried sending the sysex without the request, so maybe it’s just spitting out the garbage that i forcefed it.
any help is much appreciated, as i am pulling my hair out over here.
thanks!
james
