I would love to use this in my MIDISID,
http://www.optrex.com/products/partdetail.asp?PartNumber=C-51505NFQJ-LB-AE
will it work?
THanks for any help!
will it work?
Yes it will or not ![]()
Once Optrex reveals the controller or compatibility to HD44780 - It works.
It’s up to you to be experimental or check the datasheet againts HD44780 based displays. Do whatever you like.
Do it! - It might be an experience,
Moebius
Datasheet says: NT3881D controller, which is NOT compatible to the HD44780!
Datashet Display:http://www.optrex.com/SiteImages/PartList/SPEC/51505aee.pdf
But it should be possible to modify the HD44780 driver for this controller.
Look at the datasheet: http://www.apollodisplays.com/pdf/NT3881D.pdf
Thanks for the input-
seems way over my head fred…
I am capable of soldering the ribbon cable etc, but not modifying drivers.. ??? . etc… damn… so pretty…  ![]()
damn… so pretty…Â Â
It does look tasty! :![]()
Is that the first of it’s kind? Seems I’ve seen many different blues on blacks (maybe not that exact color).
