short answer - nope cant help…but in service manual the LCD part of the LCD-Assembly is named:
LCD: EDMMR03Y00
get the service manual, maybe you find the correct Pin-Out of the Display…
you can get the wrong dimensions… maybe the mounting holes are not on the correct position… for that you have to unmount the unit, and make some measure on your own.
Then when you unmount the lcd…maybe there is some more info on it…maybe a graphical chip, that can tell us more…
if you dont find out what Display it is - you have to look into the service manual - pinout like i said.
good look
how ever this has nothing to do with midibox construction.
http://elektrotanya.com/yamaha_rs-7000_sm.pdf/download.html
“Display (LCD) 64 x 240 dot graphic LCD with backlighting and contrast control”
in the wiring sheet u see it is a 12pole(CN10) connector going to the LCD and a 2ple connector (CN17) (+5V Backlight)
we have to focus on CN10 … the polarity of CN17 you can test with an Multimeter.
on site 18 of the service manual you can see that the Backlightpanel and the LCD panel are seperate parts
what brings me to the next step - is the backlight dead or the LCD?
on the site 28 you have the pinout of the LCD controller … we want to find out the connector CN10 and the pinout of it… CN10 is situatet on the DM-Board…nope…no pinout in the manuel, so have to see on the chips - pinout…
but bevore buy anything: take a look on the Block diagram on page 14: “cont.VR -12V” — the contrast circuit is on the Digital Main board “DM”
so the crapical chip could be dead, the contrast circuit, the LED-Backlight, or the LED-Backlight - circuit (5V) - or the LCD-part
