I already tried it, instead I gave 220ohm 100ohm, and the result is the same, I have to buy 47ohm and try it with them. But that’s LED VU meter does not work for MIDI tracks is very interesting. I joined with other users MIDIBOXU_LC and also it does not work. But as has been described above, it is about AET SONAR software.
Instead of buying a 47 Ohm resistor you could also connect two 100 Ohm resistors in parallel -> this will result into 50 Ohm, which is ok for testing.
