I just tested and discovered also the third behavior.
What your saying is even wrong it’s the bottom row which act when you select page + mute and the top row which is muting!
Seriously what the point selecting step while muting or track with the third behavior?
I can’t even go back to standard step edit whitout powering it off, it’s stuck in a weird mode where it show a detailed each step information!
This machine is a total mess, it’s a shame it could have been excellent, but there is so much work to make it just less buggy and more usable to actual standard workflow!
Like the song , to set a 128 step song, you need to set the measure per step + the pattern synchro which is in fact disabled, to work, as only the step by measure should be set, and pattern synchro an eventual override, also pattern sync and enabling should be in the same option page!
And f course no info in the quick manual about this!
I’m sorry if i sometimes rude, but please understand:
My back is hurting like the hell!
I did this device four years ago, and has been in storage till i decided to give a second try!
I’m sorry but the multiple actual buggy/inconsistent workflow is just even with the second try the hell.
I did a review to warn people 4 years ago, and most of them have confirmed.
This device is incredibly capable, but i prefer to use an mpc one, or an arturia beat step pro, or even cubase if i could, it so much more efficient, however i don’t do it because, i need 128-256 step/pattern chaining with mutiple memory slot (here 16, vs 8 for the qy700, but only one patten) select able (jam) which this device is the only one having all in one, and the mpc, is just cubase like, so not a step sequencer!
- I did not received any update from my last try to improve it with the person which apparently was the most capable to do it, so i thought he didn’t care, but i was wrong and i’m sorry gain to be rude in this one!
I still think that if we can manage that people can use it mostly without getting the manual, it would outperform the circklon , which had much more user , so much more feedback, and much more consistent workflow!
In summary, it don’t miss a lot to make it the best of these type!
The best HW sequencer isn’t the most powerful one, but the one you can use straight out of the box, and make patterns as fast as music flow, arturia, akai know it so much!
Of course there is the blm, but cirklon didn’t and is better workflow, and frankly on the bed having already this one and a controller for the synth is well enough space!
