Hello,
Hold down, If you think i blame you you’re totally wrong!
I just want to involve you in the full thinking i got for improving the ui/making actually a consistent, most user happy, behavior to value workflow!
I’m sorry you see it like this, but you know it’s like this when you arguing about thing, as i’ve manufactured a lot of business ui, i was arguing which a lot of different people, most over the developers where always thinking they were blamed because they took a way alone, and this way is arguable as soon as other notified it, and as no use case prior the dev, it ended like this!
This project involved only yourself at the beginning, but now we are about 100 user, so you’re no more alone.
You’re always been the most one to respect, but i think it’s time to open more widely your development to user point of view without thinking, that every request is in order to blame you, and that the criticism which insn’t blame is the key point in order to advance in ui improvement or any domain.
If everything is good, you never improve like one of my managers was saying, so he did never put over 95% of goal achievement, even if everything was perfect and you did not get any criticism on them!
Frankly, i would love that someone just blame me for the two album i put on share, even get a ton of criticism, you should be honored, that people look at your work, instead of having the felling of being blamed!
Ignorance of someone work by people is perhaps the worst thing you can get!
The way i work is easy, i take a picture, see what is wrong, write idea in how to remove/improve the issue.
Now as i said whatever it is for after muting or unmuting, or both, this isn’t a worth to value behavior against the track+mute option, however it can’t stay like this because it doesn’t accommodate all user!
As i said the most easier, flexible with 100% of user accommodation is to add the three option:
option auto select unmuted track
option auto select muted track
option auto select un/muted track
Also, take into account that a professional UI designer, when he do something, he want it the best for all, not only for himself.
Frankly i don’t use track+mute page as well as i already set the option to disable auto select.
However and again I want it to benefit for most user.
Rgds,
Ps: if you asked me about a use case it’s simple:
The tx81z use one channel for voice edit.
The pattern use ch1-8.
So the first thing i need is to mute then select the channel i want to edit
Set the channel of the track to the corresponding voice channel of the tx81z.
Edit the voice on the tx81z.
Unmute the channel on the seq4v+ in order to get the sound.
Another use case:
Let’s say i want to edit the channel but before i want to mute all others,
The last muted channel should be selected prior to voice edit.
Another use case:
I want to edit something muted before unmut it.
It valid the option of un/mute with selection.
Another one, i want to mute track 2-8 and select the last track.
Of course i want to mute unmute channel 2 and 8 and select the last muted for edit!
Use case i can find you so much…
