i was talking about the ALPS encoder . not the wheel rubbing or datawheel knob
in the WILBA design the datawheel encoder is the only soldered on the rear of the PCB:
http://www.midibox.org/dokuwiki/lib/exe/detail.php?id=wilba_mb_seq_construction_guide&media=wilba_mb_seq:spacer_locations.jpg
with ALPS stec 12 it’s difficult to mount it on the rear , bending the lateral fixation legs in a reverse way for soldering is not ideal .
that why on my SEQ i have mounted all encoder on the front of the PCB.
but if you solder the encoder on a little piece of perfboard (with lateral fixation legs straight/centered not externally bended ) and drill holes near each lateral fixation legs on the perfboard (distance between each holes equal distance of the two hole for fixation leg on the PCB)
you could attach/fix the encoder on the rear of PCB with two screw and nuts…so you win some space for the datawheel knob shaft…
sorry for my english , i don’t use the good words or syntax… oops
