Modified CV project to detune notes.
I’ve modified the CV midi to include a bank of 12 X 3 position slide switches which allows to select either 0 cent +50 cent & -50cent for detuning the 12 note scale .
However, during power-up, the existing implementation of the software doesn’t retain the pre-selected switch positions. Currently, to overcome this, it is required to slide the switch from short circuit to open circuit and back to short circuit position.
Can anybody suggest, if there’s a routine in any midi projects which I could use to solve this problem. I may be able to fix this by hardware using a diode and associated RC circuitry by producing a momentary open circuit state during power up. Then followed by a voltage decay step to the intended short circuit state.
Thanks
I see that I’m getting an overwhelming response to my post… :sad:
How bout it Thorsten… If you have time, could you please comment to the previous post.
Best regards
SMC
