TK about mixed CLCD/GLCD:
< base_url >/topic/16415-midibox-cv-v2-concept/?do=embed&embedComment=161480&embedDo=findComment
maybe it is already implemented, the actual bootloader says:
[2781.832] help [2781.832] Welcome to Bootloader 1.018! [2781.832] Following commands are available: [2781.832]set fastboot \<1 or 0\>:if 1, the initial bootloader wait phase will be skipped (current: 1) [2781.832]set single\_usb \<1 or 0\>: if 1, USB will only be initialized for a single port (current: 1) [2781.832]set spi\_midi \<1 or 0\>:if 1, SPI MIDI interface will be enabled (current: 0) [2781.833]set enforce\_usb\_device \<1 or 0\>: if 1, USB device mode will be enforced (current: 0) [2781.833]set device\_id \<value\>: sets MIOS32 Device ID to given value (current: 0 resp. 0x00) [2781.833]set usb\_name \<name\>: sets USB device name (current: 'Proton') [2781.833]set lcd\_type \<value\>: sets LCD type ID (current: 0x00 - CLCD) [2781.833]set lcd\_num\_x \<value\>: sets number of LCD devices (X direction, current: 2) [2781.834]set lcd\_num\_y \<value\>: sets number of LCD devices (Y direction, current: 1) [2781.835]set lcd\_width \<value\>: sets width of a single LCD (current: 128) [2781.835]set lcd\_height \<value\>: sets height of a single LCD (current: 64) [2781.835] lcd\_types: lists all known LCD types [2781.835] testlcdpin: type this command to get further informations about this testmode. [2781.835] store: stores the changed settings in flash (and updates all LCDs) [2781.835] restore: restores previous settings from flash [2781.835] reset: resets the MIDIbox (!) [2781.835] help:this page [2823.093] lcd\_types [2823.094] List of known LCD types: [2823.094] 0x00: CLCD [2823.094] 0x01: CLCD\_DOG [2823.094] 0x80: GLCD\_CUSTOM [2823.094] 0x81: GLCD\_KS0108 [2823.094] 0x82: GLCD\_KS0108\_INVCS [2823.094] 0x83: GLCD\_DOG [2823.094] 0x84: GLCD\_SSD1306 [2823.094] 0x85: GLCD\_SSD1306\_ROTATED [2823.095] 0x86: GLCD\_SED1520 [2823.095] You can change a LCD type with 'set lcd\_type \<value\>' [2823.095] Please note that newer types could have been integrated after this application has been released!
lcd_type will set all Displays to the same Type (i think)
i want to mix one 2x40 CLCD with 2 GLCD (SSD1206) on a STM32F4 core
where to start? i bet i have to use “GLCD_CUSTOM”, and have to write a custom driver - which i actually dont know how to. but maybe someone has already.
thx 4 help
