Hello,
I would like to give my application MIOS32 File Browser capabilities. Having not found much information about this, I just started playing around a bit:
Reading other peoples source codes, my impression is that the corresponding code is in terminal.c (LoopA and Seq4 code - is my impression correct?). Thus, I have begun by adding
TERMINAL\_Init(0);
into my APP_Init routine. Further, I added several programming models to my Makefile:
################################################################################ # Include source modules via additional makefiles ################################################################################ # sources of programming model include $(MIOS32\_PATH)/programming\_models/traditional/programming\_model.mk # application specific LCD driver (selected via makefile variable) include $(MIOS32\_PATH)/modules/app\_lcd/$(LCD)/app\_lcd.mk # MIDI Router (and port handling) include $(MIOS32\_PATH)/modules/midi\_router/midi\_router.mk # MIDImon include $(MIOS32\_PATH)/modules/midimon/midimon.mk # UIP driver include $(MIOS32\_PATH)/modules/uip/uip.mk # UIP Standard Task (with DHCPC + OSC server and client) include $(MIOS32\_PATH)/modules/uip\_task\_standard/uip\_task\_standard.mk # generic sequencer modules #include $(MIOS32\_PATH)/modules/sequencer/sequencer.mk # MIDI file Player #include $(MIOS32\_PATH)/modules/midifile/midifile.mk # FATFS Driver include $(MIOS32\_PATH)/modules/fatfs/fatfs.mk # FILE Access Layer include $(MIOS32\_PATH)/modules/file/file.mk # USB Mass Storage Device Driver include $(MIOS32\_PATH)/modules/msd/msd.mk # common make rules # Please keep this include statement at the end of this Makefile. Add new modules above. include $(MIOS32\_PATH)/include/makefile/common.mk
and also put the MUTEX routines into mios32_config.h:
// map MIDI mutex to UIP task // located in app.c to access MIDI IN/OUT mutex from external extern void APP\_MUTEX\_MIDIOUT\_Take(void); extern void APP\_MUTEX\_MIDIOUT\_Give(void); extern void APP\_MUTEX\_MIDIIN\_Take(void); extern void APP\_MUTEX\_MIDIIN\_Give(void); #define UIP\_TASK\_MUTEX\_MIDIOUT\_TAKE { APP\_MUTEX\_MIDIOUT\_Take(); } #define UIP\_TASK\_MUTEX\_MIDIOUT\_GIVE { APP\_MUTEX\_MIDIOUT\_Give(); } #define UIP\_TASK\_MUTEX\_MIDIIN\_TAKE { APP\_MUTEX\_MIDIIN\_Take(); } #define UIP\_TASK\_MUTEX\_MIDIIN\_GIVE { APP\_MUTEX\_MIDIIN\_Give(); }
Similarly, I have the following in my app.c:
///////////////////////////////////////////////////////////////////////////// //! functions to access MIDI IN/Out Mutex //! see also mios32\_config.h ///////////////////////////////////////////////////////////////////////////// void APP\_MUTEX\_MIDIOUT\_Take(void) { MUTEX\_MIDIOUT\_TAKE; } void APP\_MUTEX\_MIDIOUT\_Give(void) { MUTEX\_MIDIOUT\_GIVE; } void APP\_MUTEX\_MIDIIN\_Take(void) { MUTEX\_MIDIIN\_TAKE; } void APP\_MUTEX\_MIDIIN\_Give(void) { MUTEX\_MIDIIN\_GIVE; }
Yet, I still get the following error messages, and have not found a solution yet.
Quote
app.c:339:37: error: ‘MUTEX_MIDIOUT_TAKE’ undeclared (first use in this function)
app.c:339:37: note: each undeclared identifier is reported only once for each function it appears in
app.c: In function ‘APP_MUTEX_MIDIOUT_Give’:
app.c:340:37: error: ‘MUTEX_MIDIOUT_GIVE’ undeclared (first use in this function)
app.c: In function ‘APP_MUTEX_MIDIIN_Take’:
app.c:341:36: error: ‘MUTEX_MIDIIN_TAKE’ undeclared (first use in this function)
app.c: In function ‘APP_MUTEX_MIDIIN_Give’:
app.c:342:36: error: ‘MUTEX_MIDIIN_GIVE’ undeclared (first use in this function)
I hope I am not on the completely wrong path for the MIOS32 File Browser implementation ![]()
Cheers,
Karg
