In order to get rid of the windows propritary MPASM assembler, I started to migrate MIOS and most of the applications to the GPUTILS toolchain. This freeware is available for all major operating systems (including Windows/Linux/Mac OS), and therefore should allow everbody to customize and rebuild an application without Windows installation.
The main reason why this important step had not been done in the last years was the incompatibility of the GPASM macro preprocessor, which is less powerful than MPASM. Especially my beloved IFSET and IFCLR macros are not supported. As a compromise I’m using simple versions of this macro now (e.g. BRA_IFSET, BRA_IFCLR, CALL_IFSET, etc…), and converted the existing source codes to this new scheme with a perl script, and adapted the remaining cases (which were not covered by the automation) manually.
These changes are finished now, and instead of providing the quick&dirty conversion script for Unix users, I decided to maintain all existing applications with the new “GPUTILS” style in future.
For MIDIbox end-users this change is less dramatical when it sounds above - GPUTILS can be easily installed, thereafter an application can be rebuilt by typing “make” in the command shell (or windows users: by double-clicking the make.bat file). It’s simpler and requires less tools than ever before!
Following projects have already been adapted - the remaining packages will be migrated soon!
All of them got a new version number. Only exception: the mios source code package (to avoid additional effort at my side…)
change_id_v1_9d.zip
magic_midi_delay_v1_5a.zip
mbhp_tv_v1_3a.zip
midi_benchmark_v1a.zip
midibox64_v2_4a.zip
midibox64e_v2_2a.zip
midibox_cv_v1_2a.zip
midibox_fm_v1_1b.zip
midibox_lc_v1_6b.zip
midibox_mf_v2_2a.zip
midibox_seq_v2_4d.zip
midibox_seq_v3_2b.zip
midibox_sid_v1_7303c.zip
midibox_sid_v2_0_rc17.zip
midibox_tc_v1_7a.zip
midimon_v2_0a.zip
midio128_v2_1e.zip
mios_v1_9f_src.zip
skeleton_v1_9a.zip
/Edit: I uploaded all .zip packages again, only change: “make distclean” Makefile rule replaced by “make cleanall”, since the name “distclean” could be misleading.
this means that MPASM could not be used anymore for newer developments or that we can ALSO use the new GPUTILS?
There is no need to use MPASM anymore, and it’s strongly recommented to publish applications GPASM-compatible in future, so that even Linux and Mac OS users are able to customize an application, and to create a new .hex file. Thats the reason, why I’m planning to re-release all my own applications, which isn’t so much effort at all.
GPASM is slightly incompatible to MPASM (macro expansion), MPASM is slightly incompatible to GPASM (cannot handle files w/o DOS-style linefeeds, cannot handle filepathes longer than 63 characters). But at the end GPASM brings us more advantages than MPASM.
If somebody encounters issues with the usage of GPASM, or with the conversion of an old, selfwritten application, just ask in the Assembler programming section for help. I’m willing to support you during the migration, I could also do this for you (it takes ca. 1 minute) if desired.
TK: but you still can use MPASM with the updated sources? I have a crappy Pc on a corner just for this kind of things, easier than installing the other stuff on Mac ;D
You don’t really know what is going on, hm? GPUTILS is a 470k package and easier to install than MPLAB. Yes, you can still use MPASM, some files have to be converted so that they contain the DOS style linefeeds again. You also need to specify the target processor explicitely now, and sometimes you have to add an include path.
…the microchip suite was the only reason why i had a double boot x86, time to clean up the hard drive!
i haven t tried gputils yet to build asm code (just the little _asm code in my first C application, osx) but i am looking forward to, there is a MBLC+MB64 on the bench soon.
May I add a small suggestion for an alternative text editor for Windows. I’ve been using the UK written TextPad, for a long time now. It’s a bit cheaper than UltraEdit, and has a lot of community support for it’s syntax highlighting. (there are lots of syntax files available for free download). The evaluation version does no more than ‘nag’ on startup, otherwise you get the full version. I’m not saying it’s in any way better than UltraEdit and certainly not Emacs, but it’s one I got used to, and does a good job for me.
There is an old story that in the full expert version of Emacs there is a ‘make universe’ command, (they say Emacs is the editor of the gods).
This may be counterproductive but FWIW I’m a big fan of Notepad++… I actually had the credit card out, ready to buy UE, and decided I’d better try to find a freebie before I coughed up, and this is the perfect candidate.
Add the explorer plugin (which I think actually comes with it now) and compare plugin, and it does everything that UE does, but is open source and free. Similarly to TP, it has a configurable highlighter and you can share your highlighting files. C and ASM come standard. There’s also output window and debugger plugins so you could compile and debug your MIOS app from within the GUI if you want (I haven’t documented how to do this, as the codeblocks tutorial on the wiki has it covered) and it does search/replace with regexps and all kind of stuff that even UE won’t do. Recommended.
I’ve just had a classic example of Finagles law (“The Peversity of the universe tends to a maximium”).
In my last batch of scrap, I have just discovered a fully working Microchip MPLAB ICD2 programmer/in circuit debugger. Which of course runs from MPASM…
