Mios 8 problem
Here is my presentation, (sorry for my english :rofl: ) im from spain and my interest learn new things, i see this project and think is very interesting.
An here is my problem:
i have two pcs of pic 18f452 then i burn the botloader from file mios8 v1.9h
selected the file pic18f452>burner>botloader v1.2b.hex
with the pickit2, then verified
put the pics on core module and start mios studio 2.4.6.
the core continusly send:
[7720.384] f0 00 00 7e 40 01 f7
i think this is incomplete upload request from core.
…And can not upload mios studio :no:  :no:
it is possible missing id? in the wiki says that is done trougt a application change id, but it is done trought midi and i not have mios installed.
any know the hacking hex file method?
any other bootloader for pic 18f452?
Thanks
what else does MIOS Studio send and receive when you try to upload Mios8?
Thanks for your answer,
Here is the core responses:
Scanning for MIDI Inputs…
[1] Dispositivo de audio USB (*)
MIDI Monitor ready.
[101.839] f0 00 00 01 f7
[103.732] f0 00 00 7e 40 01 f7
[105.625] f0 00 00 7e 40 01 f7
[107.516] f0 00 00 7e 40 01 f7
[109.409] f0 00 00 7e 40 01 f7
and mios studio send:
Scanning for MIDI Outputs…
[2] Dispositivo de audio USB [2]
[3] Sint. SW de tabla de ondas GS
MIDI Monitor ready.
[ 96.169] f0 00 00 7e 32 00 00 01 f7
[ 96.170] f0 00 00 7e 40 00 0d 02 00 00 00 00 00 00 01 00 00 00 00 f7
[ 96.386] f0 00 00 7e 40 00 02 00 00 00 01 10 11 12 13 14 15 16 17 18 19 1a f7
[ 96.602] f0 00 00 7e 40 00 02 00 00 00 01 10 11 12 13 14 15 16 17 18 19 1a f7
[ 96.817] f0 00 00 7e 40 00 02 00 00 00 01 10 11 12 13 14 15 16 17 18 19 1a f7
[ 97.032] f0 00 00 7e 40 00 02 00 00 00 01 10 11 12 13 14 15 16 17 18 19 1a f7
[ 97.247] f0 00 00 7e 40 00 02 00 00 00 01 10 11 12 13 14 15 16 17 18 19 1a f7
when i push query:
No response from MIOS8 or MIOS32 core!
Check MIDI IN/OUT connections
and Device ID!
For debugging see also
Help->MIDI Troubleshooting
and when i try to update mios:
Reading mios8_v1_9h_pic18f452.hex
Trying to contact the core…
mios8_v1_9h_pic18f452.hex contains 12826 bytes (52 blocks).
Range 0x00000000-0x00002fff (12288 bytes) - MIOS8 area
Range 0x00003000-0x000033ff (1024 bytes) - PIC Flash
Range 0x00007c00-0x00007fff (1024 bytes) - PIC Flash
WARNING: no response from core
Please reboot the core (e.g. turning off/on power)!
Waiting for upload request…
and i do the loopback test and it worked.. :sad:
Did you also set the correct ID in MIOS Studio itself?
Try to set it to 1.
It seems that your PIC programmer hasn’t programmed the ID field, it’s probably 0xff (all-one).
See this page how to solve this: http://www.ucapps.de/howto_debug_midi.html
Search for “TEST SW2”
