Thorsten,
Questiion: The order of MIO and DOUT PCBs cards and jumpers is LPC to matrix pcbs first in line then the 3 DOUT4X PCBs, Using ribbon cable and connectors makes the Vs terminals inaccessible. Can I just drill a hole in the ground plane on the DOUTS, install a pin connector with soldered ground lead?
Question: with the core 8 Dout Chain, Is only one connectiion from Vs on J1 of the first DOUT to the system ground sufficient. The existing interconnecting jumpers are 24Ga copper, 0.5 inch long, soldered, J2 to J1 inbetween each card. Would it harm to install a larger ga ground from each Vs jumper between PCBs to the common system ground? Each Uln2803 serves 4 Sams, two 40 ohm magnets each on adjacent DOUT pins, but the on and off coils are not energized at the same time, so max load per PCB is 4.8 amps. On the core 8 chain with 4 DOUT4X PCBs at 4.8 amps thats 19.2 amps. Realistically, one magnet on every SAM either going on or off is not probable, so applying a diversity factor of 70%, there could be a 13 amp load which could explain why some of the SAMS are not moving as fast as others. In any event voltage drop in the 24-26ga wire sizes whether ribbon or solid conductor becomes an issue. Granted 90 or higher ohm magnets would be good, but we use what we have.
perhaps, Smash would consider higher capacity ground traces on the DOUT4X Pcbs with a higher capacity ground lug apart from J1 and J2.
Question: Would it be better to use one multi-voltage PS providing DC for the LPC at 3 or 5vdc regulatrd, 5vdc, regulated for Core 8 and each I/O PCB and a stiff 12vdc at 20-30 amps for SAMS, eliminating the Vs cable link in the card to card jumpers, and powering every card through a fuse directly from the PS, or possibly a fuseholder on the PCB.
Question: Is it possible to insert a low power LED on both DIN4X and DOUT4X as well as MIO PCBS to monitor either shift register action, or clock pulses to be able to flush out SR chip issues.
The LPC core is super. Thanks Thorsten - I can see several great applications utilizing the horsepower of the unit with regard to pipe organs and virtual organs. Unfortunately, i am a bit too old to start a new carrer in programming. If anyone out there is interested in a discussiion on the subject, please send me a personal email.
At this point, IMHO, there is only one organ function that a midibox based organ relay can’t do, and thats provide the software to implement a combination action system. The hardware can do it, and MIOS and midio128 Ver3. already provides for the I/O functions, but not the capture action, storage and combination retrieval. Why have to use a PC or a Mac to run jOrgan, miditzer, hauptwerk when the LPC hac the smarts to do it all?
Thanks,
Johnc
