Steve (or anyone)- What else is done besides a pullup added at RC3 and the crystal swap for the 18f speed? I’ve got all the old and new schematics at the studio with the box, but no internet there.
There are two 10kohm pull up resistors (check new core diagram) and ‘bypass’ capacitors, and I think there is one more resistor? (I’ll check when I get home) You can probably skip the bypass caps though. Also the backlight dimmer circuit needs to be modified… I just put a 220R 1W resistor in series with the backlight (5V) and removed the backlight transistor and base resistor from the circuit.
I think thats it… Oh, and check the core diagram for bankstick connections
oh yeah, I didn’t worry about the 100R resistor.
I am also going to try a switch to change between 10Mhz and 20Mhz Xtals if I want to change to an old firmware (PIC16F877)
Thanks! I’ll take this with me to the studio. I skimmed over the old and new schematics the other night too. I had more trouble figuring out where the different MBHP circuits connected to each other than anything else, but it wasn’t hard. I’m stuck in a mix right now, so I haven’t been able to do electronics out there for a couple nights. I’m anxious to see this 2x40 display in action.
I’ve still got stuff to do to my 64 before I can start construction. Some of the unneeded IC’s will likely come out, and I need to rig up temporary switches, pots, LED’s to see what I’ll use.
Like you, I figured I’d end up with an 18f on here when I was populating the board, so I ground away a recess in the PIC socket surrounding the can. Should be an easy swap.
Just a reminder… Greg’s PCB isn’t recommended for new boxes… unless you have one already lying around waiting to be used, or you only want a MB64 with 64pots, 16 Led’s. and 24 pushbuttons… otherwise it gets quite tricky down the track!
Thanks again for all the info. This is going to be a cue level controller for the tracking room, so it will mostly need knobs (which the Greg board seems to have plenty of). I’ve also got the add-on board if I need it. My next one should be with MBHP boards.
                                       -George
PS- I’ve got these MIDIBox guts sitting on a table, staring at me every night when I go in, and I’m stuck cleaning up a mix full of mismatch sample rate noises >:( I feel like I’ve made about six thousand crossfades in the past two days and I may be stuck doing them again tonight.
