Sorry, but are we talking about the banks for saving patterns? There are so many concepts in the SEQ V4 so I get a bit confused… I have not had the opportunity to use my sequencer so much yet, but it sounds to me that the drawback of a bit longer copy time is worth it for twice the space for saved patterns.
Yes, each bank stores 64 patterns, and I’m normaly using a separate bank for each group (e.g. one bank with drum patterns, one with bassline patterns and synth lines, one for filling the song, another for loopback sequences to transpose/arpeggiate other patterns)
Are there some news about the implementation of the synth preset recording and sending feature ?
It’s half finished, but especially since a mkdir() is available now, there is no blocking point anymore
I would like to use single preset dumps and multi dumps.
Each synth should have a dedicated preset dump folder with a single and a multi folder in it.
already available, just create /SYSEX/<mysynthfolder>
If possible also Subdirectories for Soundcategories would be usful (pad,lead,bass…)
Do you really want such a deep hierarchie?
Just create three folders for your synth
Have you already tried to navigate through the SysEx menu?
It’s really fast - I don’t really see a need for subcategories!
Possibility to assign a preset dump folder to a track and its corresponding midi in and output.
Not implemented yet
I also would like to send preset dump request messages to the synths, because some synths doesnt have
a option to send dumps from the hardware manually (like the yamaha tx81z!!!).
The dump request message could be placed in a txt file which lies in the single and multi folder.
Not implemented yet, but prepared
(you are just quoting the concept that I wrote some times ago in a different thread ;))
When pushing a button on the seqv4, the seqv4 should send a dump request to the synth.
After the dump request was sent, the seqv4 should record incoming dumps.
Then switch to the next synth and do it again.
Thats the way how it will work.
It’s already possible to send dumps by pushing a button, have you already tried this?
Is it working at your side?
I would like to choose a preset in a folder and then use forward backward buttons to send them to
the synth without to push an extra button (like the forward and backward buttons on a synth)
If possible, during the sequencer is running.
How would you exactly like to edit such a list?
Would a .txt file with references to the dumps be sufficient?
I’m not sure if I will find the time and motivation to integrate such an editor into the firmware (no usecase for myself)
Possibility to save all used synth presets with the whole project/song.
Again: how exactly would you like to edit this? I don’t see a clear vision how the UI should be realized.
I know this will not be easy but it would be a complete set of features to work without computer.
It would be interesting how many people would really work this way, so that I know if it is really worth the effort to integrate additional editors so that absolutely no computer is required.
To repeat Strophlex’ statement:
and this is what many people are saying.
