MIDIbox Quad Genesis
The text is no good, it’s plain lines and not a scan engrave text soi need to edit it. The lines are single lines and also not etch able these need editing also. The numbers are the same. Other than that it is OK. Just needs cleaning.
Thanks SSP. The cutting came out great! Well done! Hell I’d even label it manually myself if needs be. Let me know if you have any suggestions. Thanks a million, Smithy.
As soon as I have some free time I will edit it and run it again.
Update especially for people who have ordered Sauraen’s Front Panel PCBs.
TLDR: I have 4 Front Panels and 4 Rear Panels for MIDIbox Quad Genesis for sale.
Life got in the way of both me and , and we lost contact for a few years!
Thanks for your help dude, and if anyone would like acrylic panels laser cut you should contact him!
The good news is that I ended up converting the Front Panels in .fpd format to PCB format using Kicad with lots of editing and learning.
Here’s how the Front Panels came out:
I also designedRear Panels and this is how they turned out:
Please note that the mounting holes for the Front Panel are designed to fit the DIY Wooden Enclosure that  designed for me:
http://www.midibox.org/dokuwiki/doku.php?id=mbqg_tb_case
You will need to use brass inserts that take 3mm bolts, drilled into the top of the case to be able to mount it.
I will update the  I’m making with details on how to do this:
The rear panel will require using a jigsaw or small saw to cut out the rectangle for the Rear Panel.
I am really happy the way the precision of the Edge Cuts and how the silkscreen came out.
The Front Panel PCBs fit Saureans green pcb underneath perfectly as you can see in the first image embedded
Unfortunately JLCPCB did not put paper between the pcbs despite me paying for that option and 2  Front Panel PCBs had had minor scuffs:
Nothing a Sharpie Pen couldn’t fix though.
If you are interested PM me and I can try and get a price for shipping it to your country.
Just posting to see if there’s any interest now.
Really pleased for you they have come out really good. Shame about the scuffs, make sure you email them highlighting the damage and your payment for correct shipping, they may offer replacements. Looking forward to seeing the build!!!
Thanks dude! I filed a complaint with JLCPCB to get a refund due to absence of paper between the PCBs which I paid for and also a partial refund for the scuffed boards.
hei, what do you payed on jlpcb for one set (devidet)?
is there a change to get a Sauren Frontpanel PCB anywhere?
Hey phatline, I paid a total of $184.26 for the 5 sets of the front panel and rear panel PCBs. I’m negotiating a partial refund for the lack of paper and the 2 boards with marks on them.
So that’s $37 for 1x Front Panel and 1x Rear panel.
I *think* Sauraen may have some green MBQG_FP PCBs  that have not been sold, a few years ago he had some left at least.
He is on travels at the moment so may not reply until he is home.
The Genesis module PCBs are sold out on Modular Addict, so I’m not sure if any more are available. The MIDIbox Shop is closed down and Modular Addict (USA) is the new shop for PCBs.
https://modularaddict.com/shop-by-brand/midibox-ucapps-de
Best to check with Sauraen, another friend of mine is interested in buying a set of Sauraens PCBs and my panels also.
I also need to try and prioritize the people who already have MBQG_FP PCBs.
 I could try and get some more people interested in buying PCBs by posting on relevant Synth DIY facebook groups and forums.
When I complete the build guide I think more people would be enticed to build their own.
Thanks for your time,
Smithy.
ok - i wrote sauren.
if i get feedback from him - that he have a pcb - then i ask you @Smithy again - if you still have a pcb-frontpanel then.
  • mike.
if i get feedback from him - that he have a pcb - then i ask you @Smithy again - if you still have a alu-pcb then.
  • mike.
Hey man. It’s actually an FR4-Standard PCB. Non aluminium. But seems pretty robust anyway.
Also check out the wooden case that Technobreath designed. It’s a simple case based on Sauraen’s metal enclosure that he repurposed.
I modified the 8 mounting holes so they would fit the wooden case.
I’ll be using 8 threaded inserts for m3 screws that I bought on eBay.
You can find the pdf here:
http://wiki.midibox.org/doku.php?id=mbqg_tb_case
Just found a cheap source on AliExpress for the m3 threaded inserts for wood:
https://a.aliexpress.com/_EwPghFj
Be sure to select m3xm5x6mm
i’ve PM you.
G
