??? ?? ??? ? Led Rihgs ??? 16 ??? ??? DOUT ??? “???” ??? ?? ?? 11 ? ?? 16 ??? ?
à ÷î Ãåëüçÿ…ìîæÃî…Ãà äà â êîäå ñìîòðåòü êà ê ðåà ëèçîâà Ãî Ãà 11…
napishi translitom ) , a to neponyatnye simvoly vmesto teksta (
blya chota s kodirovkoy…nado smotret’ kak realizovano v kode na 11 i perepisat’ na 16 ))) schaz netu vremeni s etim razbiratsya i v blijayshem buduschem ne ojidaetsa
Ðичего не могу поделать, ну не даетÑÑ Ð¼Ð½Ðµ программирование :sad:
Лазил в иÑходниках,  нашел много Ñтрочек Ñ “подходÑщим” Ñодержанием,  но точно не уверен что те Ñтроки надо изменÑть, ÑÐµÐ¹Ñ‡Ð°Ñ Ð¿Ð¾Ð¿Ñ€Ð¾Ð±ÑƒÑŽ разобратьÑÑ Ñ Ð¿Ñ€Ð¾Ñ†ÐµÑÑом ÐºÐ¾Ð¼Ð¿Ð¸Ð»Ð¸Ñ€Ð¾Ð²Ð°Ð½Ð¸Ñ hex файла ,  и наверно попробую изменить main.asm )
Mozet osibocnaja mislja.
Smotrel v Midibox64e.ini :
In the LED_PATTERN section, the patterns for LED-Rings are defined
4 different patterns are available. Within a Pattern, 32 steps for CC value
range from 0x00 to 0x7f have to be assigned
The first step is visible on the appr. LED-Ring from Values 00-03,
the second from 04-07, the third from 08-0b, …
SYNTAX: <pattern-number(0-3)>.<step-hex-value(00-1F)> <16-bit-binary-value>
[LED_PATTERNS]
0.00 = 0000000000000001
0.01 = 0000000000000001
0.02 = 0000000000000011
0.03 = 0000000000000011
0.04 = 0000000000000011
0.05 = 0000000000000111
0.06 = 0000000000000111
0.07 = 0000000000000111
0.08 = 0000000000001111
0.09 = 0000000000001111
0.0A = 0000000000001111
0.0B = 0000000000011111
0.0C = 0000000000011111
0.0D = 0000000000011111
0.0E = 0000000000111111
0.0F = 0000000000111111
0.10 = 0000000000111111
0.11 = 0000000000111111
0.12 = 0000000001111111
0.13 = 0000000001111111
0.14 = 0000000001111111
0.15 = 0000000011111111
0.16 = 0000000011111111
0.17 = 0000000011111111
0.18 = 0000000111111111
0.19 = 0000000111111111
0.1A = 0000000111111111
0.1B = 0000001111111111
0.1C = 0000001111111111
0.1D = 0000001111111111
0.1E = 0000011111111111
0.1F = 0000011111111111
Etot odin iz 4 rezimov raboti svetodiodnoi lineiki, no ne v odnom iz etih 4 rezimov v 16-ti bitovoje cislo 5 starsih razrjadov ne razu ne stanovitsja 1, a izmenenija na 1 proishodjat v 11-ti mladsih razrjadah.
Jesli eti 11 razrjadov sootvetstvuet 11 svetodiodam lineiki, to 16 razrjadov sootvetstvenno…
No v *.asm faile toze nado definirovatj zadeistvovanije registri v DOUT module
Janis
 ЕÑть режим индикации выбранного Ñнкодера, когда захожу в режим конфигурации, вокруг выбранного Ñнкодера Ñветодиодное кольцо начинает поочередно зажигать Ñветодиоды, ÑоздаетÑÑ Ñффект крутÑщейÑÑ ÑветÑщейÑÑ Ñ‚Ð¾Ñ‡ÐºÐ¸ вокруг Ñнкодера. Делал на макете. С раÑчетом на планируемое раÑширение Ñ 11 Ñветододов до 16 штук, поÑтавил Ñразу 16, и вÑе подÑоединил. ПоÑле загрузки оÑновного hex файла, при регулировке какого-либо параметра, в индикации кольца работают 11 Ñветодиодов,  как показано на оÑновной Ñхеме. Ркогда захожу в режим  конфигурации работы Ñнкодеров,  выделающее  кольцо поочередно зажигает  вÑе 16.Â
Когда чертил печатную  плату на 11 диодные колечки, получаетÑÑ Â Ð´Ð¾Ð²Ð¾Ð»ÑŒÐ½Ð¾ громоздко. Ðа 16 наверно  придетÑÑ Â Ñветодиоды приклеивать к  панели и паÑть проводками.
