midi channel selector
Hello
This is probably a really stupid question but is it possible to implement a midi channel selector (either a rotary encoder or just a push button that incrementally increases) into a midibox 64 project.
All I want to be able to do is shift all the front panel controls to a different midi channel via the selector.
I know absolutely nothing about MIOS but have read this site and forum repeatedly and can’t seem to find an answer.
Cheers
Carl
hi,
just use the bank:
assign all control of bank 1 to channel 1, bank 2 to channel 2, etc…
you can add up to 16 butons to access bank directly, or you can change bank with the jog..
let see the mb64 tutorial…
cheers
I figured it would be blatently obvious
::slight_smile:
Note that there is also a “global channel”, which overrides all MIDI Channel definitions for the pots and buttons. It can be enabled in the appr. menu page
TK,
So you mean if I have 4 channels with eq and I use another buttons connected to the core i can assign those 4 channel to another 4 channels on the bank?, I mean like changing the channels but using the same hard? ???
