MF kill switch
So,
If your motorfaders are not touch sensitive, you can use a switch to interrupt the motors, and allow you to make adjustments without damaging the faders…
Must you use 1 switch per fader, or does 1 switch turn off all faders’ motors simultaneously?
Has anyone tried using a footswitch to trigger this?  It seems this would be the least intrusive way to handle non-touch-sensitive boards.
The touchsensitivity is there to stop the motor and let you move it to other postitions (so you can do that in the middle of a recording and delete the old automation).
Because of that: There’s one switch for each Fader (otherwise it would be stupid - you never would be able to only stop one fader).
Instead of a footswitch you also can only use a small metall plate to induce touchsensitivity (just touch the metall plate and simultaniously move the fader).
I wouldn´t recommend 8 foot switches under your table…  ;)
