Thanks for the help TK!
I created the /SESSIONS/DEFAULT/MBSEQ_C.V4 file manually with the one value you noted.
After that I proceeded with what the change log says.
[46991.390] set osc_remote 3 10.101.80.144
[46991.393] Set OSC3 Remote address to 10.101.80.144
[46997.486] set osc_local_port 3 8000
[46997.489] Set OSC3 Local port to 8000
[47002.414] set osc_remote_port 3 8000
[47002.417] Set OSC3 Remote port to 8000
[47007.182] set osc_mode 3 1
[47007.184] Set OSC3 transfer mode to 1: Text Msg (Integer)
[47013.238] set blm_port OSC3
[47013.241] BLM port set to OSC3
[47027.958] store
[47028.283] Failed to store session on SD Card: /SESSIONS/DEFAULT
[47031.902] sdcard
[47031.904] SD Card Informations
[47031.904] ====================
[47031.904] --------------------
[47031.904] CID:
[47031.905] - ManufacturerID:
[47031.905] - OEM AppliID:
[47031.905] - ProdName: SU04G
[47031.905] - ProdRev: 128
[47031.905] - ProdSN: 0x04e4292f
[47031.905] - Reserved1: 45
[47031.905] - ManufactDate: 188
[47031.905] - msd_CRC: 0x7b
[47031.905] - Reserved2: 1
[47031.905] --------------------
[47031.905] - CSDStruct: 1
[47031.905] - SysSpecVersion: 0
[47031.905] - Reserved1: 0
[47031.905] - TAAC: 14
[47031.905] - NSAC: 0
[47031.905] - MaxBusClkFrec: 50
[47031.906] - CardComdClasses: 1461
[47031.906] - RdBlockLen: 9
[47031.906] - PartBlockRead: 0
[47031.906] - WrBlockMisalign: 0
[47031.906] - RdBlockMisalign: 0
[47031.906] - DSRImpl: 0
[47031.906] - Reserved2: 0
[47031.906] - DeviceSize: 7562
[47031.906] - MaxRdCurrentVDDMin: 0
[47031.906] - MaxRdCurrentVDDMax: 0
[47031.906] - MaxWrCurrentVDDMin: 0
[47031.907] - MaxWrCurrentVDDMax: 0
[47031.907] - DeviceSizeMul: 240
[47031.907] - EraseGrSize: 31
[47031.908] - EraseGrMul: 28
[47031.908] - WrProtectGrSize: 0
[47031.908] - WrProtectGrEnable: 0
[47031.908] - ManDeflECC: 0
[47031.908] - WrSpeedFact: 2
[47031.908] - MaxWrBlockLen: 9
[47031.908] - WriteBlockPaPartial: 0
[47031.908] - Reserved3: 0
[47031.908] - ContentProtectAppli: 0
[47031.908] - FileFormatGrouop: 0
[47031.908] - CopyFlag: 1
[47031.908] - PermWrProtect: 0
[47031.908] - TempWrProtect: 0
[47031.908] - FileFormat: 0
[47031.908] - ECC: 0
[47031.908] - msd_CRC: 0x5c
[47031.908] - Reserved4: 1
[47031.908] --------------------
[47031.908]
[47031.908] Reading Root Directory
[47031.908] ======================
[47031.908] Retrieving SD Card informations - please wait!
[47031.909] SD Card: ‘’: 3951 of 3955 MB free
[47031.910] [.h..l.a] 04/11/12 10:01:42 AM 4096 _~1.TRA
[47031.910] […a] 00/00/-20 00:00:00 AM 2080 MBSEQ_BM.V4
[47031.910] [.h..ld.] 04/11/12 10:01:42 AM <DIR> 0 TRASHE~1
[47031.910] [.h..ld.] 04/11/12 10:01:42 AM <DIR> 0 FSEVEN~1
[47031.910] [.h..ld.] 04/11/12 10:01:46 AM <DIR> 0 SPOTLI~1
[47031.911] […a] 00/00/-20 00:00:00 AM 850 MBSEQ_GC.V4
[47031.911] [.h..ld.] 04/12/12 03:40:08 PM <DIR> 0 TEMPOR~1
[47031.911] […d.] 04/12/12 03:38:30 PM <DIR> 0 SESSIONS
[47031.912] [.h..l.a] 04/12/12 03:40:08 PM 4096 _~1.TEM
[47031.912]
[47031.912] Checking SD Card at application layer
[47031.913] =====================================
[47031.913] Current session: /SESSIONS/DEFAULT
[47031.913] File /SESSIONS/DEFAULT/MBSEQ_B1.V4: doesn’t exist
[47031.914] File /SESSIONS/DEFAULT/MBSEQ_B2.V4: doesn’t exist
[47031.914] File /SESSIONS/DEFAULT/MBSEQ_B3.V4: doesn’t exist
[47031.914] File /SESSIONS/DEFAULT/MBSEQ_B4.V4: doesn’t exist
[47031.914] File /SESSIONS/DEFAULT/MBSEQ_M.V4: doesn’t exist
[47031.914] File /SESSIONS/DEFAULT/MBSEQ_S.V4: doesn’t exist
[47031.914] File /SESSIONS/DEFAULT/MBSEQ_G.V4: valid
[47031.914] File /SESSIONS/DEFAULT/MBSEQ_BM.V4: valid
[47031.914] File /SESSIONS/DEFAULT/MBSEQ_C.V4: valid
[47031.914] File /MBSEQ_C.V4: valid
[47031.914] File /MBSEQ_BM.V4: valid
[47031.914] File /MBSEQ_HW.V4: doesn’t exist or hasn’t been re-loaded
[47031.914] done.
After that I checked the file on the sdcard and it had populated with these settings in addition to my manual one:
BPMx10_P 0 750 0
BPMx10_P 1 800 0
BPMx10_P 2 850 0
BPMx10_P 3 900 0
BPMx10_P 4 950 0
BPMx10_P 5 1000 0
BPMx10_P 6 1050 0
BPMx10_P 7 1100 0
BPMx10_P 8 1150 0
BPMx10_P 9 1200 0
BPMx10_P 10 1250 0
BPMx10_P 11 1300 0
BPMx10_P 12 1350 0
BPMx10_P 13 1400 0
BPMx10_P 14 1450 0
BPMx10_P 15 1500 0
BPM_Preset 13
BPM_Mode 0
QuickSelLength 4 8 16 24 32 64 128 256
QuickSelLoopLength 4 8 12 16 16 32 32 32
QuickSelLoopLoop 1 5 9 13 1 1 17 25
LastSong 1
LastMixerMap 1
LastPattern 1 1:A1
LastPattern 2 2:A1
LastPattern 3 3:A1
LastPattern 4 4:A1
SynchedPatternChange 0
SynchedMute 0
SynchedUnmute 0
RATOPC 0
StepsPerMeasure 15
StepsPerPattern 15
GlobalScale 0
GlobalScaleCtrl 0
GlobalScaleRoot 0
LoopMode 0
LoopOffset 1
LoopSteps 16
MIDI_DefaultPort 32
MIDI_BUS_Channel 0 1
MIDI_BUS_Port 0 0
MIDI_BUS_Lower 0 0
MIDI_BUS_Upper 0 127
MIDI_BUS_Options 0 0x00
MIDI_BUS_Channel 1 2
MIDI_BUS_Port 1 0
MIDI_BUS_Lower 1 0
MIDI_BUS_Upper 1 127
MIDI_BUS_Options 1 0x00
MIDI_BUS_Channel 2 3
MIDI_BUS_Port 2 0
MIDI_BUS_Lower 2 0
MIDI_BUS_Upper 2 127
MIDI_BUS_Options 2 0x00
MIDI_BUS_Channel 3 4
MIDI_BUS_Port 3 0
MIDI_BUS_Lower 3 0
MIDI_BUS_Upper 3 127
MIDI_BUS_Options 3 0x00
MIDI_IN_MClock_Ports 0x010f0f01
MIDI_IN_RecChannel 1
MIDI_IN_RecPort 0
MIDI_IN_SectChannel 0
MIDI_IN_SectPort 0
MIDI_IN_SectFwdPort 0
MIDI_IN_SectNotes 48 60 72 84
MIDI_OUT_MClock_Ports 0xffffffff
MIDI_RouterNode 0 0 0 32 0
MIDI_RouterNode 1 0 0 32 0
MIDI_RouterNode 2 0 0 32 0
MIDI_RouterNode 3 0 0 32 0
MIDI_RouterNode 4 0 0 32 0
MIDI_RouterNode 5 0 0 32 0
MIDI_RouterNode 6 0 0 32 0
MIDI_RouterNode 7 0 0 32 0
MIDI_RouterNode 8 0 0 32 0
MIDI_RouterNode 9 0 0 32 0
MIDI_RouterNode 10 0 0 32 0
MIDI_RouterNode 11 0 0 32 0
MIDI_RouterNode 12 0 0 32 0
MIDI_RouterNode 13 0 0 32 0
MIDI_RouterNode 14 0 0 32 0
MIDI_RouterNode 15 0 0 32 0
It must be the act of storing that is putting the above values?
Here is my “global” output as well:
[49774.525] global
[49774.527] Global Configuration:
[49774.527] =====================
[49774.527] MetronomePort 0
[49774.527] MetronomeChannel 10
[49774.527] MetronomeNoteM 37
[49774.527] MetronomeNoteB 37
[49774.527] PasteClrAll 1
[49774.527] MultiPortEnableFlags 0x011011
[49774.528] RemoteMode 0
[49774.528] RemotePort 0
[49774.528] RemoteID 0
[49774.528] CV_AOUT_Type 0
[49774.528] CV_PinMode 0 0 0 2
[49774.528] CV_PinMode 1 0 0 2
[49774.528] CV_PinMode 2 0 0 2
[49774.528] CV_PinMode 3 0 0 2
[49774.528] CV_PinMode 4 0 0 2
[49774.528] CV_PinMode 5 0 0 2
[49774.528] CV_PinMode 6 0 0 2
[49774.528] CV_PinMode 7 0 0 2
[49774.529] CV_GateInv 0x00
[49774.529] CV_ClkPulsewidth 1
[49774.529] CV_ClkDivider 16
[49774.529] BLM_SCALAR_Port 66
[49774.529] ETH_LocalIp 192.168.2.100
[49774.529] ETH_Netmask 255.255.255.0
[49774.529] ETH_Gateway 192.168.2.1
[49774.529] ETH_Dhcp 1
[49774.529] OSC_RemoteIp 0 192.168.1.101
[49774.529] OSC_RemotePort 0 8001
[49774.529] OSC_LocalPort 0 8000
[49774.530] OSC_TransferMode 0 0
[49774.530] OSC_RemoteIp 1 192.168.1.101
[49774.530] OSC_RemotePort 1 8001
[49774.530] OSC_LocalPort 1 8000
[49774.530] OSC_TransferMode 1 0
[49774.530] OSC_RemoteIp 2 10.101.80.144
[49774.530] OSC_RemotePort 2 8000
[49774.530] OSC_LocalPort 2 8000
[49774.530] OSC_TransferMode 2 1
[49774.530] OSC_RemoteIp 3 192.168.1.101
[49774.531] OSC_RemotePort 3 8001
[49774.531] OSC_LocalPort 3 8000
[49774.531] OSC_TransferMode 3 0
[49774.531] done.
Still not working on MIDI out 1 sadly, but you’ve giving me some more info as to what needs to be configured, so I thank you greatly for this education. I will play with this some more and see if I can get it working.
