Hello
I wanted to know if some one have a Schaeffer files for the front panel of MB808 .
Thank you
Zephyrin
Hello
Thank you
Zephyrin
Hi Zaphyrin,
for the case that it helps: I got my acryl panel (premade) from http://frontplaten.net
http://discourse.midibox.org/t/topic/12323
You could ask him for the design data of the panel that he created for me (it has some corrections) - or just order an Acryl panel from him, which is definitely less expensive than an aluminum based panel from Schaeffer. ![]()
Thank you for your answer Thorsten.
I don’t have the doug’s or moogha PCB, i have make the keyboad with vero board so the key are not at the same place.
Also i have used the 3 microlarge PCB with full mod and i have more pot than you.
I will try to contact Richard for know if he can help me
