The “ideal” length I specified is for when the cable is stiff and can’t bend much. Any longer and the case won’t close. Maybe very flexible cable could form another bend in it when closed, but unlikely.
In your situation, I suggest marking where you would get 42mm of insulation, cutting the insulation between the wires up to that point, then stripping off the insulation using wire cutters, instead of the “score and pull” method that I found worked better for the stiff cable.
Moving the insulation like you suggest might lead to other problems, so I wouldn’t recommend it.
Thanks for the advice wilba. I actually tried it that way (after scoring the cable), but after seeing the marks i decided to stop. Should be fine this time.
I used the 6" ribbon from mouser that were already pre-scored at the ends cables and soldered them from the underside of the control surface to the top side of the base board. I just tucked the rest inside making sure that the cable did not fold completely. The nice thing about the longer cable is that I can take the top off and unscrew the baseboard without additional cable tension. I’ve had no problems with them. I can post some pictures if that helps.
HI Digineural, thanks for the reply!
I’m using the same cable you described, ordered it from Mouser too.
I would really appreciate the pics, as im trying to figure out how you tucked them in.
I bought 10, already ruined one, and since I need 8 cables + 1 with only 2 wires for the 5v / GND, i dont really want to risk damaging the 9th one.
Sure no problem. You might want to gently prebend the ends then hook the boards together before soldering. since these are semi rigid cables, when it comes time to bend the cable they will be aligned quite well. I’ve opened and closed this case about 15 times when adding the fan and other miscellany. So far the cables haven’t snapped.
