Right, as i made a monumental fuck up in aligning the pcb with the panel, i think I better give a warning to people who are considering having
Countersunk Corner Holes & Screws in their panel..
Bottomline is, that you should not use the 4 Screws to align the panel with the PCB,
as they will not be perfectly perpendicular to the back of the panel, because they will have room to move around in the countersunk holes., (unless you’re lucky)
This is basically what happened:
I put the 4 countersunk screws through the holes at the front of the panel, and i used a spring washer and nut on the opposite side of each screw, to lock them into the back of the panel.
When trying to mount the PCB, i realized that it was easy to get 3 screws through the holes of the PCB,
but it was tricky to get all 4 screws through the holes.
Looking back now, this was a warning sign that the screws were NOT perfectly aligned / perpendicular at that time, but i assumed i was not holding the pcb perfectly horizontal while trying to drop it into the screws.
I also used 2 additional nuts per screw, each were either side of the PCB to hold it in place.
And i inserted some switches as directed by the guide to help with the alignment.
It was only after the 24 hours of applying the weld, and clamping the pcb and panel together,
that i realized the shafts of switches were pushed a bit diagonally.
This was because the threaded spacers were between 0.5mm and 1mm too far to the left of the back panel (out of alignment),
and the switches (being the weakest) were forced to the side.
What i would recommend from my experience,
is to not use the screws to align the panel and pcb,
but to actually solder the switches first and use the switches to align them.
Obviously before you solder the switches to the PCB, be sure to mark off where the standoffs go on the panel, as stated in the guide.
You will have to be extra careful not to push a Switch into a blob of JB Weld,
in particular the button for SID L R, as that is the closest switch to a standoff.
Remember this is only for people using countersunk corner holes/screws.
Might be a better idea to use non-countersunk holes and button head screws, as they should be perfectly perpendicular to the panel.
Or even better use no holes at all, and weld the 4 screws to the back of the panel as Wilba did in the guide.
