Apologies if this is redundant, but I didn’t see a similar post anywhere else in the forum, so I thought I’d share..
As I started to piece together my bill of materials for an MB-6582, I realized I would have to do a lot of sorting and counting from the tables in the wiki.
I decided to copy & paste into a spreadsheet for easier pivoting and here’s what I came up
> Covers parts for the Base PCB only
> Assumes 4xCore Modules & 4 x SIDs (either 6582 or 8580, not including regulator parts for 6581)
> Uses power supply option E
| Description | Value | Qty. | Part Sourcing Links |
| Base PCB | MB-6582-BS | 1 | https://modularaddict.com/midibox-6582bs-pcb |
| Capacitor - Electrolytic (Radial) | 100µF 25v | 1 | https://www.mouser.com/ProductDetail/140-RGA101M1EBK0611G |
| | 10µF 25v | 9 | https://www.mouser.com/ProductDetail/140-RGA100M1EBK0511G |
| | 1µF 50v | 8 | https://www.mouser.com/ProductDetail/140-SEA1R0M1HBK0407 |
| | 2200µF, 16V (or 25V) | 1 | https://www.mouser.com/ProductDetail/140-REA222M1EBK1625P |
| Capacitor - Metal Film | 22nF | 16 | https://www.mouser.com/ProductDetail/667-ECQ-E4223RKF |
| Capacitor - MLCC | 100nF | 36 | https://www.mouser.com/ProductDetail/594-K104K15X7RF53H5 |
| | 1nF | 16 | https://www.mouser.com/ProductDetail/594-K102M15X7RF53L2 |
| | 33pF | 8 | https://www.mouser.com/ProductDetail/594-K330J15C0GF5TH5 |
| | 470pF | 8 | https://www.mouser.com/ProductDetail/594-K471K15X7RF53H5 |
| Crystal | 10MHz | 4 | https://www.mouser.com/ProductDetail/815-ABL-10-B1U |
| DIN Socket | 5-Pin | 2 | https://www.mouser.com/ProductDetail/57PC5F |
| | 7-Pin | 1 | https://amzn.to/3bCe4cx (Amazon - hard to find these days) |
| Diode | 1N4148 | 5 | https://www.mouser.com/ProductDetail/1N4148 |
| Header | 2-Pin | 2 | Any |
| | 3-Pin | 9 | Any |
| | 4-Pin | 1 | Any |
| | 4-Pin Dual row | 1 | Any |
| | 8-Pin Dual row | 4 | Any |
| IC | 24LC512 - 512K EPROM | 8 | https://www.mouser.com/ProductDetail/24LC512-I-P |
| | 6N138 Optocoupler | 1 | https://www.mouser.com/ProductDetail/630-6N138 |
| | 74HC165 - Shift Reg (Parallel to Serial) | 5 | https://www.mouser.com/ProductDetail/595-SN74HC165N |
| | 74HC595 - Shift Reg (Serial to Parallel) | 11 | https://www.mouser.com/ProductDetail/595-SN74HC595NE4 |
| | PIC18F4685 Microcontroller | 4 | https://www.mouser.com/ProductDetail/PIC18F4685-I-P |
| | SID 6581/6582/8580 | 8 | Check eBay or Etsy - Good luck! |
| IC Socket | 16-Pin | 16 | https://www.mouser.com/ProductDetail/485-2203 |
| | 28-Pin | 8 | https://www.mouser.com/ProductDetail/485-2206 |
| | 40-Pin | 4 | https://www.mouser.com/ProductDetail/485-2207 |
| | 8-Pin | 9 | https://www.mouser.com/ProductDetail/485-2202 |
| Potentiometer - Rotary | 100K - Dual Gang | 4 | https://www.mouser.com/ProductDetail/313-1250F-100K |
| Potentiometer - Trimmer | 10K | 5 | https://www.mouser.com/ProductDetail/PT6KV-103A2020-PM |
| Resistor | 1.2K 1/4 1% | 4 | https://www.mouser.com/ProductDetail/271-1.2K-RC |
| | 100 Ohm 1/4W 1% | 4 | https://www.mouser.com/ProductDetail/271-100-RC |
| | 10K 1/4W 1% | 25 | https://www.mouser.com/ProductDetail/271-10K-RC |
| | 1K 1/4W 1% | 34 | https://www.mouser.com/ProductDetail/271-1K-RC |
| | 220 Ohm 1/4W 1% | 20 | https://www.mouser.com/ProductDetail/271-220-RC |
| | 5.6K 1/4W 1% | 1 | https://www.mouser.com/ProductDetail/271-5.6K/AP-RC |
| Resistor network (5-pin or 6-pin) | 10K | 10 | https://www.mouser.com/ProductDetail/264-10K-RC |
| Stereo Phono Jack with Switch | Neutrik - NMJ6HFD2 | 4 | https://www.mouser.com/ProductDetail/550-20301 |
| Toggle Switch | Salecom T80-R | 1 | https://www.retroleum.co.uk/c64-misc-components-fuse-etc |
| Transistor | BC337 | 1 | https://www.mouser.com/ProductDetail/610-BC337 |
| | BC547 | 16 | https://www.mouser.com/ProductDetail/512-BC547ATA |
| Voltage Regulator | 5V SREG | 1 | https://www.mouser.com/ProductDetail/919-R-78B5.0-1.5 |
| | 7809 1A | 1 | https://www.mouser.com/ProductDetail/511-L7809ABV-DG |
| Component Grand Total | | 338 | |
Cheers!
