PS- There are probably a few archived posts here from me looking for DIY parallel MIDI circuits over the years. It’s really surprising that there weren’t any out there.
I didnt know that it is possible to connect via LPT…
I have an Opcode patchbay providing 8 ins and outs through the parallel port, and it has a lot of standalone features, it’s impressive, considering it’s 100% made of easy to find parts (software is on ROM chips ).
Yes, but does it actually cooperate in 2008?? ;D
I’ve got a nice MOTU parallel box that I don’t trust for crap here due to its flaky 2K/XP drivers and a small MIDIMan 1x1 which does serial over one of those 25 pin ports (stuck at 98SE). Also an Opcode 2x6 rack box which is old Mac serial.
If Plog’s driver and circuit do OK, it might be cool to share some board swap designs for some of those old boxes. I redid the board for that 1x1 MIDIMan Portman box a while back, to switch over to a 9-pin serial connector, and still have the layout and hole diagrams:
BTW- That had PICs in it too. I think it was three 16C54 chips. The box itself is solid as a rock though, all steel and feels like you could run over it with a car without killing it.
George
PS Plog- That 98 driver would be great too. I’ve run some decent 98 machines which didn’t do well with audio & USB activity.
Yes, but does it actually cooperate in 2008?? Grin
It works well with Windows 9x, but someone took the time to make XP drivers for it (not free however) so there are no compatibility problems (except you need a parallel port).
Man, that’s cool as s***. I’m surprised I hadn’t heard about that. Which Opcode box is it, the 128? I wish more of those parallel port manufacturers had done that, but maybe it makes a difference whether the company is dead yet. I wonder if they worked with Opcode on it.
I started throwing together a layout for that tonight (because I hate breadboard ;D).
I’m guessing all those LED symbol things are just standard signal diodes, like the 4148 or something? Also guessing the MIDI i/o requires the same supplemental parts like in Thorsten’s core circuits here (the opto,resistors,etc.)?
yes its the simple led diodes=) on RB7 - indicates error, led near 8bit_register, indicates NOT ENABLED (means that if on, then device is OFF, and 8bit register is in high impedance state, the all 8 bit data leds, show value comming from LPT port, so dont be scare then you see randomly lighted leds =)
about midi i/o you are right but im just using common ground between converter and my midi ctrl without any optos & resistors.
you do not need a resistor on MIDI IN, cause its open collector (RA4 is input pin),
you don’t need a resistor on MIDI OUT too, cause its pin is from LPT control port, which means that they are already with 4.7kohm pull-up resistors
if you made some PCB’s you may share it with us =)
So they actually are LEDs. I just couldn’t figure why there were so many. I guess I should have skimmed over the whole batch of files (the asm) before asking. :-[
I’ll probably leave the MIDI i/o parts off this circuit and just put a couple pads or something to connect to, so I can change the stuff on the outside for right now.
Im planning to rewrite firmwire to support midi in & midi out in one PIC16F84A
Didn’t quite understand that part either. So, what exactly does it do for now if hit by simultaneous i/o traffic?
Thanks!
George
PS (if Stryd’s here) - So are you talking about another parallel port design? :o
