Hi guys! I’ve just started testing of my first MIDIbox as a complete set, configured for midi2CV application. It’s based on LPC17 core; aout_ng used for CV output. Currently it’s running under Midibox_ng_v1_032 and configured for high-resolution CV. CV output is okay, however I encountered a problem with gate. There is no signal at DOUT ch. 1 through 7 upon key pressure. Sure, fwd_gate_to_dout_pin… command is applied in configuration file. I checked j8/9-DOUT connection twice - it seems to be ok (according to diagram).
I see that “DOUT off” when I press shift and “all DOUT pins inactivated” when pressing button #3 on SCS. Is it the reason why gate doesn’t work? I can’t activate DOUT using SCS. Please, advise how to fix that.
PS: Sorry, posted here by mistake. This topic should be moved to
