Linux - Mios8 - Toochain - make - problems
SOLVED :santa:
LINUX - UBUNTU 14
1. Install some Software:
open “Terminal” type, and enter/install this:
sudo apt-get install gputils
Dont do this:
sudo apt-get install sdcc
  • it would install the latest version (in my case 3.3.0) - and that may dont work.
Do this:
manually download 2.8.0, unzip anyware, reading the Install.txt :
Change to the sdcc directory and copy all files to /usr/local
cd sdcc
cp -r * /usr/local
This will install sdcc binaries into: /usr/local/bin/
header files into:                          /usr/local/share/sdcc/include/
library files into:                            /usr/local/share/sdcc/lib/
and documentation into:              /usr/local/share/sdcc/doc/
You can test the install by entering
/usr/local/bin/sdcc -v
should return:
SDCC : mcs51/gbz80/z80/avr/ds390/pic16/pic14/TININative/xa51/ds400/hc08 2.8.0 #5117 (Mar 23 2008) (UNIX)
2. add some variables in the file “/etc/enviroment”
MIOS_PATH=“/mios/”
MIOS_BIN_PATH=“/mios/bin”
MIOS_SHELL=“/bin/bash” <<< the " " was the problem!!!
PROCESSOR=18f452
you have to write the whole path (crimic is my username):
MIOS_PATH=“/home/crimic/mios”
MIOS_BIN_PATH=“/home/crimic/mios/bin”
MIOS_SHELL=/bin/bash
PROCESSOR=18f452
click save >>> ooops the file “Enviroment” is “Read only” - no save possible — so 1.1:
1.1 have “write rights” to change the “enviroment”
open “terminal” (console, command) tpe “gksudo” > enter > a window with a clear field pop up > type “nautilus” (nautilus is the “explorer”/“filemanagement” of ubuntu) > nautilus now pop up > navigate to /etc/enviroment > add following lines @ the end of the document:
PROCESSOR=18f452
 This Tutorial say…<Forget this Tutorial it’s outdatet!
1.2 Proove if you do right: open “terminal” type
printenv PROCESSOR
now it prints:
18f452
well done!
3. Download toolchain
well not very easy to find, in the tutorial for windows i found that mios_base_v1_1.zip
or you do it with:
svn checkout svn://svnmios.midibox.org/mios
but then you have to change the Mios paths in 1.1! (/mios/trunk…)
After download, i renamed the “mios_base_v1_1” folder into “mios” and drop the folder in my USER (deutsch Persönlicher Ordner) - so if you now open  “terminal” and you type:
cd mios
cd apps
cd examples
cd lcd7
cd dog
cd c
make
this should build/make an application but i get errors:
rm -rf _output/*
rm -rf _output
rm -rf *.cod *.map *.lst
rm -rf *.hex
mkdir -p _output
/bin/bash /home/crimic/mios/bin/mios-gpasm -c -p p18f452 -I./src -I /home/crimic/mios/include/asm -I /home/crimic/mios/include/share -I /home/crimic/mios/modules/app_lcd/dog -DDEBUG_MODE=0  -DSTACK_HEAD=0x37f -DSTACK_IRQ_HEAD=0x33f -I /home/crimic/mios/modules/mios_wrapper /home/crimic/mios/modules/mios_wrapper/mios_wrapper.asm  -o _output/mios_wrapper.o
/bin/bash /home/crimic/mios/bin/mios-gpasm -c -p p18f452 -I./src -I /home/crimic/mios/include/asm -I /home/crimic/mios/include/share -I /home/crimic/mios/modules/app_lcd/dog -DDEBUG_MODE=0   /home/crimic/mios/modules/app_lcd/dog/app_lcd.asm -o _output/app_lcd.o
/bin/bash /home/crimic/mios/bin/mios-sdcc -c -mpic16 -p18f452 --fommit-frame-pointer --optimize-goto --optimize-cmp --disable-warning 85 --obanksel=2  -I./src -I /home/crimic/mios/include/c -I /home/crimic/mios/include/share -DDEBUG_MODE=0  main.c -o _output/main.o
at 1: warning 118: option ‘–fommit-frame-pointer-�’ no longer supported  ‘use --fomit-frame-pointer instead’
at 1: warning 117: unknown compiler option ‘–optimize-goto’ ignored
In file included from main.c:17:
/usr/bin/../share/sdcc/include/pic16/pic18fregs.h:427:25: error: pic18f452.h: No such file or directory
/home/crimic/mios/include/c/cmios.h:245: syntax error: token -> ‘char’ ; column 43
make: *** [_output/main.o] Fehler 1
well this path /user/bin is really no such file or directory!!!
but this exist:
/usr/share/sdcc/include/pic16
of course i would love to simply make a 32bit applicaton, and use the new cores, but i have 10 or more 8bit cores here!!! I shame to waste them! — and for my things (triggerbox for techstar ts306) it is really enough.
Hi!
I just install it to try it on my linux computer (Slackware, but it shouldn’t be too different from ubuntu).
I had the same error as you get.
You can try to fix by editing mios-sdcc (mios/bin/mios-sdcc) and add “–use-non-free” as sdcc parameter
My sdcc-mios looks like that now :
# $Id: mios-sdcc 444 2008-08-14 21:26:28Z tk $
# MIOS specific wrapper for sdcc
# Executes sdcc
# Uses "mios-gpasm -fixasm" wrapper to assemble the generated code
# Thorsten Klose (2008-02-03)
# SYNTAX: mios-sdcc <sdcc-arguments>
if [-z "${MIOS_BIN_PATH:-}"]; then
  echo "ERROR $0: MIOS_BIN_PATH variable not set!"
  exit 1
fi
sdcc --use-non-free --asm="${MIOS_SHELL} ${MIOS_BIN_PATH}/mios-gpasm -fixasm" $@
I still have another error (according to your log you don’t have it)
pilo@linux-pilo:~/src/mios/mios/trunk/apps/examples/lcd7/dog/c$ make
rm -rf _output/*
rm -rf _output
rm -rf *.hex
mkdir -p _output
/bin/bash /home/pilo/src/mios/mios/trunk/bin/mios-gpasm -c -p p18f452 -I./src -I /home/pilo/src/mios/mios/trunk/include/asm -I /home/pilo/src/mios/mios/trunk/include/share -I /home/pilo/src/mios/mios/trunk/modules/app_lcd/dog -DDEBUG_MODE=0 -DSTACK_HEAD=0x37f -DSTACK_IRQ_HEAD=0x33f -I /home/pilo/src/mios/mios/trunk/modules/mios_wrapper /home/pilo/src/mios/mios/trunk/modules/mios_wrapper/mios_wrapper.asm -o _output/mios_wrapper.o
/bin/bash /home/pilo/src/mios/mios/trunk/bin/mios-gpasm -c -p p18f452 -I./src -I /home/pilo/src/mios/mios/trunk/include/asm -I /home/pilo/src/mios/mios/trunk/include/share -I /home/pilo/src/mios/mios/trunk/modules/app_lcd/dog -DDEBUG_MODE=0 /home/pilo/src/mios/mios/trunk/modules/app_lcd/dog/app_lcd.asm -o _output/app_lcd.o
/bin/bash /home/pilo/src/mios/mios/trunk/bin/mios-sdcc -c -mpic16 -p18f452 --fommit-frame-pointer --optimize-goto --optimize-cmp --disable-warning 85 --obanksel=2 -I./src -I /home/pilo/src/mios/mios/trunk/include/c -I /home/pilo/src/mios/mios/trunk/include/share -DDEBUG_MODE=0 main.c -o _output/main.o
at 1: warning 118: option '--fommit-frame-pointer-ÿ' no longer supported 'use --fomit-frame-pointer instead'
at 1: warning 117: unknown compiler option '--optimize-goto' ignored
/home/pilo/src/mios/mios/trunk/include/c/cmios.h:250: syntax error: token -> 'char' ; column 43
make: *** [_output/main.o] Error 1
(might be a compile flag I didn’t set when I compile sdcc from source)
To answer you question:
  1. Yes it seems it’s correct
  2. You can also grab the latest code from the svn (svn checkout svn://svnmios.midibox.org/mios if you have svn installed). Then you’ll find everything in mios/trunk/)
I’ll try to fix my setup, and I hope you’ll manage to make yours working!
thx for the try… i tried “use non free”, i got:
crimic@diesmalnet:~/mios/apps/examples/lcd7/dog/c$ make
rm -rf _output/*
rm -rf _output
rm -rf *.hex
mkdir -p _output
/bin/share/sdcc /home/crimic/mios/bin/mios-gpasm -c -p p18f452 -I./src -I /home/crimic/mios/include/asm -I /home/crimic/mios/include/share -I /home/crimic/mios/modules/app_lcd/dog -DDEBUG_MODE=0  -DSTACK_HEAD=0x37f -DSTACK_IRQ_HEAD=0x33f -I /home/crimic/mios/modules/mios_wrapper /home/crimic/mios/modules/mios_wrapper/mios_wrapper.asm  -o _output/mios_wrapper.o
make: /bin/share/sdcc: Kommando nicht gefunden (English: command not found)
make: *** [_output/mios_wrapper.o] Fehler 127 (English: Error 127)
in /bin are Files only - so no Folder… but “/usr/share/sdcc” exist — I dont know what to do with that information!
asm works, sdcc not:
crimic@sichanet:~/mios/apps/templates/ sdcc _skeleton$ make
rm -rf _output/*
rm -rf _output
rm -rf *.hex
mkdir -p _output
/bin/share/sdcc /home/crimic/mios/bin/mios-gpasm -c -p p18f452 -I./src -I /home/crimic/mios/include/asm -I /home/crimic/mios/include/share -I /home/crimic/mios/modules/debug_msg -I /home/crimic/mios/modules/app_lcd/dummy -DDEBUG_MODE=0  -DSTACK_HEAD=0x37f -DSTACK_IRQ_HEAD=0x33f -I /home/crimic/mios/modules/mios_wrapper /home/crimic/mios/modules/mios_wrapper/mios_wrapper.asm  -o _output/mios_wrapper.o
crimic@nasicha:~/mios/apps/templates/ asm _skeleton$ make
rm -rf *.cod *.lst *.err
rm -rf *.hex
gpasm  -p p18f452  -I./src -I /home/crimic/mios/include/asm -I /home/crimic/mios/include/share -I /home/crimic/mios/modules/app_lcd/dummy  main.asm
sdcc version:
sdcc 3.3.0+dfsg-1ubuntu1
You’ve to use sdcc 2.8.0, please don’t try any other version because only this release has been qualified.
A linux version can be downloaded from: http://sourceforge.net/projects/sdcc/files/sdcc-linux-x86/2.8.0/
The package contains a INSTALL.txt file, just follow the instructions.
Once SDCC has been installed (e.g. under /usr/local/bin), the “sdcc --version” command should return
SDCC : mcs51/gbz80/z80/avr/ds390/pic16/pic14/TININative/xa51/ds400/hc08 2.8.0 #5117 (Mar 23 2008) (Mac OS X i386)
If it returns another string, your PATH variable doesn’t reference the correct binary, in this case try to uninstall the other versions that you’ve installed so far.
Once this has been done, the original mios8 makefiles will work without modifications (no need to set special flags etc.)
hi,
I tried 3.3.0 - dont worked
I also tried 2.9.0 - dont worked
I also tried 2.8.0 - dont worked - proved:
After that i erased all Flags, after then - a other try: (nope)
crimic@anonymus:~/mios/apps/templates/sdcc_skeleton$ make
rm -rf _output/*
rm -rf _output
rm -rf *.hex
mkdir -p _output
hm
As mentioned above: you’ve to use SDCC 2.8.0, no other version will work properly.
This message:
tells you, that the sdcc command hasn’t been found under /bin/share/sdcc
This isn’t a problem with 2.8.0, but with your unix shell setup.
The big question is: why is it searched under /bin/share, and not under /usr/local/bin or wherever you installed sdcc
What surprises me:
you are able to retrieve the version - how exactly did you do that?
well I dont know why it searches under /bin and not in /usr - no clue really
how i did that? - i did what you said, i opened the terminal and typed sdcc --version:
crimic@nixgibts:~$ sdcc --version
this http://www.midibox.org/dokuwiki/doku.php?id=installing_gputils_and_sdcc_on_ubuntu_8.04
sould be changed — because if you do so like described
  • it install always the latest version (in my case 3.3.0) - and that may dont work.
manually download 2.8.0, unzip anyware, reading the Install.txt, > should do the job
Install.txt says: Change to the sdcc directory and copy all files to /usr/local
cd sdcc
cp -r * /usr/local
You can test the install by entering:
should print:
Seems that this wiki page is outdated. It has been written 2009, at this point of time SDCC 2.8.0 was the “latest and greatest” version.
Meanwhile a newer SDCC version is provided by default, but it isn’t compatible with MIOS8 anymore.
Hopefully a Linux user who was able to install the tools successfully will update this page, otherwise many people will come across this inconsistent information in future and they will be stucked (like you).
However, I’m unsure how I can help you.
For me it looks like you did some changes in the original files which come with the MIOS8 repository.
Unfortunately my crystal ball shows only white smoke there :wink:
If you enter:
cat $MIOS_BIN_PATH/mios-sdcc
what do you see at the last line?
It should be:
sdcc --asm="${MIOS_SHELL} ${MIOS_BIN_PATH}/mios-gpasm -fixasm" $@
If you see something else (e.g. a direct path reference to sdcc), then we found out that you’ve modified this file… :wink:
the mios is untouched and blank from: http://www.ucapps.de/mios/mios_base_v1_1.zip, i dont changed any app or so, i just typed “make” by some sdcc apps, to try it out
give:
crimic@nixhak:~$ cat $MIOS_BIN_PATH/mios-sdcc
Executes sdcc
Uses “mios-gpasm -fixasm” wrapper to assemble the generated code
if [-z “${MIOS_BIN_PATH:-}”]; then
  echo “ERROR $0: MIOS_BIN_PATH variable not set!”
  exit 1
fi
sdcc --asm=“${MIOS_SHELL} ${MIOS_BIN_PATH}/mios-gpasm -fixasm” $@
What is the output of:
which sdcc
This is not a problem with sdcc install, because here what the makefile is trying to execute :
I don’t know why sdcc and mios-gpasm are mixed here, but it should be only :
edit:
Maybe it’s the path to bin that is not correct?
echo $MIOS_BIN_PATH should tell you “/home/crimic/mios/bin”
and it seems it’s set on “/bin/share/sdcc /home/crimic/mios/bin”
This output would happen if Phatline has set the MIOS_SHELL variable by accident, e.g. to /bin/share/sdcc
Actually this variable shouldn’t be set at all -. I added this due to a special user request some time ago, but it’s more or less a hidden feature and should only be used when you know what you are doing :wink:
So Phatline: please enter
unset MIOS_SHELL
and try it again
reply deleted, since I don’t use sdcc (SID apps are in asm).
I just removed lastest sdcc version and installed sdcc from the link provided by TK, and everything works as expected now :slight_smile: (without any modification).
crimic@sowiso:~$ which sdcc
/usr/local/bin/sdcc
crimic@nixgibts:~$ echo $MIOS_BIN_PATH
unset MIOS_SHELL
I did the same, i had to manually delete the files, because of manually installing but, hey… it didnt help:
after all above I got this:
crimic@naherst:~/mios/apps/templates/sdcc_skeleton$ make
rm -rf _output/*
rm -rf _output
rm -rf *.hex
mkdir -p _output
sh /home/crimic/mios/bin/mios-gpasm -c -p p18f452 -I./src -I /home/crimic/mios/include/asm -I /home/crimic/mios/include/share -I /home/crimic/mios/modules/debug_msg -I /home/crimic/mios/modules/app_lcd/dummy -DDEBUG_MODE=0  -DSTACK_HEAD=0x37f -DSTACK_IRQ_HEAD=0x33f -I /home/crimic/mios/modules/mios_wrapper /home/crimic/mios/modules/mios_wrapper/mios_wrapper.asm  -o _output/mios_wrapper.o
/home/crimic/mios/bin/mios-gpasm: 24: /home/crimic/mios/bin/mios-gpasm: declare: not found
/home/crimic/mios/bin/mios-gpasm: 27: /home/crimic/mios/bin/mios-gpasm: declare: not found
/home/crimic/mios/bin/mios-gpasm: 37: /home/crimic/mios/bin/mios-gpasm: Syntax error: “(” unexpected (expecting “fi”)
make: *** [_output/mios_wrapper.o] Fehler 2
It helps!
As you can see, the code execution continues and you get a new error.
The messages indicate an issue with the shell.
Seems that adding MIOS_SHELL is indeed no expert option, but may be required for your Linux distribution.
Could you please try:
export MIOS_SHELL=/bin/bash
had done the job!!!
+ SDCC 2.8.0
crimic@JAWOI:~/mios/apps/templates/sdcc_skeleton$ make
rm -rf _output/*
rm -rf _output
rm -rf *.hex
mkdir -p _output
/bin/bash /home/crimic/mios/bin/mios-gpasm -c -p p18f452 -I./src -I /home/crimic/mios/include/asm -I /home/crimic/mios/include/share -I /home/crimic/mios/modules/debug_msg -I /home/crimic/mios/modules/app_lcd/dummy -DDEBUG_MODE=0  -DSTACK_HEAD=0x37f -DSTACK_IRQ_HEAD=0x33f -I /home/crimic/mios/modules/mios_wrapper /home/crimic/mios/modules/mios_wrapper/mios_wrapper.asm  -o _output/mios_wrapper.o
/bin/bash /home/crimic/mios/bin/mios-gpasm -c -p p18f452 -I./src -I /home/crimic/mios/include/asm -I /home/crimic/mios/include/share -I /home/crimic/mios/modules/debug_msg -I /home/crimic/mios/modules/app_lcd/dummy -DDEBUG_MODE=0   /home/crimic/mios/modules/app_lcd/dummy/app_lcd.asm -o _output/app_lcd.o
/bin/bash /home/crimic/mios/bin/mios-sdcc -c -mpic16 -p18f452 --fommit-frame-pointer --optimize-goto --optimize-cmp --disable-warning 85 --obanksel=2  -I./src -I /home/crimic/mios/include/c -I /home/crimic/mios/include/share -I /home/crimic/mios/modules/debug_msg -DDEBUG_MODE=0  main.c -o _output/main.o
/home/crimic/mios/bin/mios-gpasm modifies _output/main.asm, result in _output/main__mios-gpasm-tmp.asm
/bin/bash /home/crimic/mios/bin/mios-gpasm -c -p p18f452 -I./src -I /home/crimic/mios/include/asm -I /home/crimic/mios/include/share -I /home/crimic/mios/modules/debug_msg -I /home/crimic/mios/modules/app_lcd/dummy -DDEBUG_MODE=0   /home/crimic/mios/modules/debug_msg/debug_msg.asm -o _output/debug_msg.o
gplink -s /home/crimic/mios/etc/lkr/p18f452.lkr -m -o project.hex  /home/crimic/mios/lib/libsdcc.lib /home/crimic/mios/lib/pic18f452.lib _output/mios_wrapper.o _output/app_lcd.o _output/main.o _output/debug_msg.o
THHHHHHANX und Danke —
ps: had edit the first Post of this topic - of course only for my own I in the future, when have to do that again…
ps2: tama techstar 306 - fired with Mios8 - c - is bouncing its first beats > thx 2 us!
I’m still struggling to setup my dev env. under Unbuntu 14 (lts)
and, i’m facing this problem : when i $ svn checkout svn://svnmios.midibox.org/mios
i have no message at all, its just stuck forever, and there’s no error, no timeout, nothing.
I assumed that the problem was temporary, so i tried everyday since a few days, but no change …
Any idea ? Is there another way to retrieve the svn data ?
Also, it would be great to update the wiki application development page, because  “Installing GPUTILS and SDCC on Ubuntu 8.04” is a bit obsolete by now :slight_smile:
(but i have no idea about how to do it)
you could download it manuall:
and then do what i have done…
