another question!
Today I had the MIDI fighter twister in my hands. It’s a 4x4 encoder box with LED rings. It’s a great USB controller… you should check it out.
Anyway: When I turned an encoder I realized that the LEDs of the ring are dimmed… so they fade slowly into full brightness depending on the value. As far as I know the LEDs on MIDIbox are just going on and off. But the fades are quite fancy No big thing but I just want to ask, if this might be able in the future with MIDIbox as well
LEDs can be dimmed with the set_rgb command in the .NGR script; however, the resolution depends on the matrix configuration; with 8 rows we’ve only 4 dim levels anymore.
Maybe 4 or 5 brightness levels are enough to give a bit of a fade-effect. I will check that with some of my led-rings. But I’m not sure how to program that into the NGR…
