LED assignment
Hi Midiboxers,
i just wondering if it is possible to change the assignment of the OP 1-4 and Instr. 1-4 LEDs?
Because there is no option in the cs_menu_io_tables…
Or is it necessary to connect them like in the FM Dout schematic?
Best regards
Marxon
These LEDs are directly assigned to the first SR in cs_menu_matrix.inc
The direct SR assignment (for all 8 pins) saves execution time and flash memory.
As you already noticed, flash is very reduced for PIC18F452… and performance is an important topic as well.
You are the master of 1´s and 0´s :smile:
I am just a little solder guy.
So i connect the LEDs like you think it is the best way to do.
Oder auf deutsch: du wirst schon wissen was du tust :smile:
Danke für die Info
Gruß
Marxon
