LCD suggestions
Hello. My LCDs from http://www.buy-display.com/ are really starting to annoy me. Basically the viewing angle is garbage. I’ve rackmounted my SEQ v4 and so I end up viewing the screen from slightly above it and it’s just horrible. I still want something that’s green on black if possible, any suggestions? Thanks.
I wasnt too thrilled with the buy-display part either.  Crappy performance, crappy build.  You get what you pay for I guess.  I use the the green on black optrex parts, they are a pain to dial in to get to look good but they do look good (eventually) and dont draw a ton of current.  I used the 40x2 newhaven ones also and like those a lot despite being your standard black on light background with backlite deals.  One thing about the optrex parts you MUST watch for is that there MUST be a current limiting resistor on the backlight or you will blow the LEDs (i’ve done it more than once).  They are replaceable if youre handy with tiny ass SMD stuff but its a $40 display in the trash otherwise
Today I installed two Noritake VFD Display’s. I bought them cheap when I was in the US. They are great and really fast, but here in Europe they are soooo expensive …
http://de.mouser.com/ProductDetail/Noritake/CU40025-UW6J/?qs=LpQOCaTXNHji3bWMnGLoCw==
$106 each is cheap?
Yes, they were. I didn’t pay $100 for them…
300mA power consumption per piece will cause some problems with standard USB power supply. Maybe this is just the peak current at “all characters lit”. Did you have any issues?
Although “self luminent” displays are to prefere over lcd displays in my opinion. A compatible oled display would be nice :slight_smile:
Well, as you mention it. I didn’t pay any attention to this detail :-). After the replacement of the green display, I haven’t connected the SEQV4 to the PC. Maybe not a good idea… I will measure the heat generated by the voltage regulator at some point and check their specs again. Not sure where there limits in terms of current are …
Thanks for the hint, I didn’t realize that they are so energetic :slight_smile: … and FAST !!
Found this a minute ago:
http://uk.farnell.com/midas/mcoc4002awmye/oled-40x2-yellow-w-t-4-font-sets/dp/2218979
Looks nice exept of the pricing … :wink:
Nice! Hopefully a green one is in the works.  Dont see too many 40x2 OLEDs
