LCD - SN102 94V0
Has anyone used a KL SN102 94V-0 LCD screen? i cant find a data sheet anywhere.
I have wired it up the same as the wiring diagram but only the backlight comes on and mios studio shuts down. when i disconnect the lcd the core module acts as normal and mios studio does’nt shut down.
Is this screen compatable with a midi box?
Hi Adamwg,
Disconnect only the backlight, it is probably causing the shutdown by dragging down your power supply.
Check the new wiki page about displays, there is a list of 44780 compatible LCD driver chips there that you can compare with your display to answer the compatibility question.
Best
SmashTV
i have just begun to paly with MIDIBOX
and have a small problem
i have a 4x20 LCD
it works almost perfect
but row 3 and 6 start printing on column 5
so i was wondering if it could be that i maby have switch 2 wires
or is it just my display that is strange ?
Row 3 & 6? … ? ;D
Look up in your main.asm. You´ll find a little table where you can adjust the offsets of all possible LCDs. High chances that there´s still the offsets for let´s say a 4x16 display in there.
Greetz! :slight_smile:
cheers smash
i dont think the lcd i have is compatible.
It would help if i could find some kind of data sheet for it. the pins seem to be straight forward they are numbered on the pcb.
There should be some manufacturer on there. Just email them and ask for it. In 70% of all cases, they can give you what you need or at least give you some hint.
People here can also only look on google, you know…
Greetz!
There is no makers name  just a part code - KL SN102 94V-0
There is a thread in a car-mp3 forum with a non-standard pinout that looks promising:
http://www.mp3car.biz/vbulletin/showthread.php?p=169814
No idea if that will work or burst into flames…Also know I found a thread in a different forum (in spanish!) that -looks like- one guy is telling another that he needs an inverter…so yours might be an extended temp range model…complete explanation on extemp LCDs is in the wiki.
BTW you can find 4x40, 4x20, and 4x16 displays from various different manufacturers…with this same part number…making a datasheet search more like a waste of time.
There are thousands of companies in China making character LCDs, cloning each other’s designs furiously.
Best
Smash
http://www.google.com.au/search?hl=en&q=SN102+LCD&meta=
LOTS of hits :slight_smile: Good luck mate.
from the doc’s on the lcd function page
i thought the lcd line arrangement was like this
//sets the text cursor on LCD screen
// 0x00-0x3f: first line
/// 0x40-0x7f: second line
// 0x80-0xbf: third line
// 0xc0-0xff: fourth line
after experimenting a little i have no clue what is going on here
made a littel simple program to test where the display was displaying
the test program
void DIN_NotifyToggle(unsigned char pin, unsigned char pin_value) __wparam
  if(pin_value == 1)
    switch(pin)
    case 0 :
    val++;
    displayTest(val);
    break;
return;
void displayTest(unsigned int val)
MIOS_LCD_Clear();
  MIOS_LCD_CursorSet(0x00);
  MIOS_LCD_PrintCString(“verdi”);
  MIOS_LCD_PrintBCD3(val);
  MIOS_LCD_CursorSet(val);
  MIOS_LCD_PrintCString(“test string to g”);
return ;
the result from the test
16 dec line 3
40 dec line 2
46 dec line 2
80 dec line 4
104 - 111 dec line 1
120 - 128 dec  line 1
148 - 155 dec line 2
164 - 172 dec line 2
188 dec line 4
212 - 219 dec line 1
104 - 111 menas that “the test string to g” starts at column 1 on line x
dont know if my display is a little strange or what
but i think i can remember when i bought the display about 8 years ago
there was somthing about that something had to be fliped, switched, reversed or negated to get it to work as an standard HD44780
or it was just me that was drunk ?
am using MIOS 1,8 and sdcc_skeleton_v1_0d
and programming in C
hope sombody has some idea what is going on here
Find me the datasheet for your LCD and I’ll tell you :slight_smile:
have tryed many times an have not found any
the only thing i have about it is
on the pcb  MDL-16465
and
SN102
94VO or 94V0
on one of the chips there is a sticke
MDLS1646S-01
MDLS1645S-LV-
it is a 4x16
there is 4 chips on it
3 x HD44100FS
1 x HD44780A00
I just merged two of the LCD issues threads here, since you guys are both fighting these displays…
One of you has a working pinout, one of you needs a pinout, etc… Time to trade notes!  ;D
Smash
LiFo: you are mixing decimal with hexadecimal numbers.
According to the documentation: http://www.ucapps.de/mios_fun.html#MIOS_LCD_YAddressSet, a 4x20 display needs following offsets:
  MIOS_LCD_YAddressSet(0x00, 0x40, 0x14, 0x54);
this function call can be inserted into the Init() hook.
Thereafter you can access the display lines with:
  MIOS_LCD_CursorSet(0x00 + <column>); // for the first line
  MIOS_LCD_CursorSet(0x40 + <column>); // for the second line
  MIOS_LCD_CursorSet(0x80 + <column>); // for the third line
  MIOS_LCD_CursorSet(0xc0 + <column>); // for the fourth line
Thorsten thanks for pointing me in the right direction
i have just started to play with MIOS and had not seen the documentation under the
MIOS_LCD_YAddressSet section
just the under the MIOS_LCD_CursorSet
MIOS_LCD_YAddressSet(0x00, 0x40, 0x10, 0x50);
solved my problem as i have a 4x16 LCD
regarding wiring i made the same wiring as on  http://www.midibox.org/users/jim_henry/building_a_midibox_lcd_cable.pdf
again Thanks
Ive finaly got hold of a data sheet for the SN102 94V0.
The pinning is standard. (the same as the wiring diagram on the lcd page)
i’m not sure why i cound’nt get it to work though. hopefully i’ll get my new pic’s soon and i can get it working.
If any one wants a copy of the data sheet i will email it to them.
I finally got the lcd to work.I got my pic’s today and it all works fine.
I think the lcd will not work unless a midi box application is loaded. I think this was probably why i could’nt get it to work before.
Great news… The LCD should work with MIOS but no application loaded…Weird… Hey, it works!
