Hi There It is been a wile, but I encountered the following problem:
My Lcd (2x20) suddenly got only A black bar on the top row.
I have made one change: I made a proper pcb for the power supply instead of a breadboard. Everything works fine, but fine I only got 4.95 V. and 13.91V for 2 SID.s Could this small difference be the problem?
It Is the complete top row. It is A Oriental Display DM2002B. And I had some problems with the CAN bus interface -it could not detect my second sid- although I followed every step for the upgrade. But every else worked fine and it did not bothered me that much at that point.
I tested the lcd back in 8-bit mode on an older Pic-core and that worked fine, so it is not fried.
Then I looked up the specs for the screen and thought I found that the problem in wrong wiring (I wired it according to the 2002C instead to the 2002B type).
But now Backlight and brightness are not working and I still have the blackrow, so the previous should have been the right one.
thanks in advance, Youri
[edit]
I also did a complete reprogram of Mios 1.9 and then the Sid 2 Application with the only thing that uploading with LCD gives the error #11 midi-in Overun. And without not.
[edit2]
How should I read the numbers on the LCD when the are not on a straight line? so I have 2 lines of 8 next to each other where, looking from above, the left bottom has 1 and the top right has a 16. I soldered from left(1)-right(2), left(3)-right(4), etc. again it did work, but just to be shure.
with the other way around you would have already fried your LCD
