A quick question that may make me seem quite foolish.
I am not certain but i think my lcd is an extended type as the backlight works but there is nothing on the screen. The screen is a YJ-162A 16x2. I have used the mios prog and checked the power on the pins and all looks good and i have rechecked my pin config and soldering both seem ok.
The question is having wired up my lcd the wrong way plugging it in and powering it up and then working out that i had mixed up the data and power pins have I broken it or are they reasonably durable and should I invest more time in making a -5V circut or should I just get a new lcd
Errr… Your post is a bit fuzzy on the details… So you applied -5V to one of the data pins? Maybe you did fry your LCD…
yes, it’s very likely that the LCD has been fried because of (temporary) mixed data/power lines
