Jsynth and Win2000 ???
Hi there!
Running on Win2000. Installed JAVA Runtime and then wanted to start JSynth. Nothing. Really absouletly nothing happens.
Anybody had this problem? How to solve it?
I use the Opera browser and installed the Java Runtime that came with it. And the JSynth works with it (on a Win2000). But not fully. E.g when trying to edit a patch with it while the SID is connected, the JSynth just freezes.
BTW, check that you have the Java Runtime in your path. Or run a command prompt and try to run the .bat “manually” from it and see what it says.
OK, I´ll try that.
