J16 as DIN/DOUT (LPC1769)
How to transform J16 in a normally connected to the SRIO chain to scan DIN/DOUT modules?
What should I change to achieve this goal?
TKS!!!
Marco.
you can switch to J16 with following define in your mios32_config.h file:
#define MIOS32\_SRIO\_SPI 0
Hi TK thanks for the reply !!
Can I use SPI0 (DIN / DOUT) and SPI1 (DIN / DOUT) simultaneously?
Unfortunately not - the SRIO driver is monolithic, it can only be assigned to a single SPI interface.
Tks TK.
I got sad :frowning:
I used this function" MIOS32_SPI_TransferByte " …and   I got some signal from the LEDs …
 MIOS32\_SPI\_Init(0); MIOS32\_SPI\_TransferModeInit(0,MIOS32\_SPI\_MODE\_CLK1\_PHASE1,MIOS32\_SPI\_PRESCALER\_128); MIOS32\_SPI\_IO\_Init(0,MIOS32\_SPI\_PIN\_DRIVER\_WEAK\_OD); MIOS32\_SPI\_RC\_PinSet(0,1,1);
Of course, you are free to service the SR register chain directly without using the SRIO driver (resp. implement a second SRIO driver)
Hi TK, do you have any examples in the forum that control SRs (j16) as the “MIOS32_DOUT_PinSet” function?
I tried to study this function, but I could not succeed.
Thanks!!
AFAIK there is no forum posting about this so far.
The shift registers are service from MIOS32_SRIO, this code has to be duplicated (and button related functions have to be removed): http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fmios32%2Fcommon%2Fmios32_srio.c
Btw.: why do you need the second SRIO chain? Wouldn’t it be easier to enhance the first chain by +16 SRs?
I need it because of the DJ program (Traktor). each side of the deck has 16 RGB LEDs (96 outputs). Missing VUs, elapsed time, LEDs for the other buttons (RGBs). Unfortunately that consumes many outputs and I’m afraid the 256 outputs will not be enough. I just want to ensure having more options for digital inputs and outputs.
I’ll try it later, I program all day and my head can not think anymore.
Sorry for my bad english.
Thanks again !! Marco.
you should consider to connect the RGB LEDs to a LED matrix, this is less expensive and also reduces the number of wires.
E.g. a 8x16x3 matrix consist of 7 x 74HC595 and allows you to connect 128 RGB LEDs.
Then just add another 8x16x3 matrix for the second deck.
Do you know the MIDIbox NG application?
It supports such features out-of-the-box: http://www.ucapps.de/midibox_ng.html
Hi Thorsten .
I did not want to use matrix, but I think I have to use.
Can I configure the outputs of the 8x16 matrix using which function? BLM_CHEAPO?
Thanks!! Marco
Hi Thorsten,
I tried using MAKE to compile MIDIBOX_NG and some errors appeared.
I:\MIOS32\trunk\apps\controllers\midibox\_ng\_v1\>make rm -f project.hex Creating object file for port.c i:/MIOS32/trunk/FreeRTOS/Source/portable/GCC/ARM\_CM3/port.c: In function 'prvPortStartFirstTask': i:/MIOS32/trunk/FreeRTOS/Source/portable/GCC/ARM\_CM3/port.c:282:1: warning: stack usage computation not supported for this target [enabled by default] Creating object file for core\_cm3.c i:/MIOS32/trunk/drivers/LPC17xx/CMSIS/src/core\_cm3.c: In function '\_\_get\_PSP': i:/MIOS32/trunk/drivers/LPC17xx/CMSIS/src/core\_cm3.c:451:1: warning: stack usage computation not supported for this target [enabled by default] Creating object file for usbcontrol.c i:/MIOS32/trunk/drivers/LPC17xx/usbstack/src/usbcontrol.c: In function 'StallControlPipe': i:/MIOS32/trunk/drivers/LPC17xx/usbstack/src/usbcontrol.c:127:6: warning: variable 'pb' set but not used [-Wunused-but-set-variable] Creating object file for psock.c i:/MIOS32/trunk/modules/uip/uip/psock.c: In function 'psock\_send': i:/MIOS32/trunk/modules/uip/uip/psock.c:179:3: warning: variable 'PT\_YIELD\_FLAG' set but not used [-Wunused-but-set-variable] i:/MIOS32/trunk/modules/uip/uip/psock.c: In function 'psock\_generator\_send': i:/MIOS32/trunk/modules/uip/uip/psock.c:218:3: warning: variable 'PT\_YIELD\_FLAG' set but not used [-Wunused-but-set-variable] i:/MIOS32/trunk/modules/uip/uip/psock.c: In function 'psock\_readto': i:/MIOS32/trunk/modules/uip/uip/psock.c:274:3: warning: variable 'PT\_YIELD\_FLAG' set but not used [-Wunused-but-set-variable] i:/MIOS32/trunk/modules/uip/uip/psock.c: In function 'psock\_readbuf': i:/MIOS32/trunk/modules/uip/uip/psock.c:301:3: warning: variable 'PT\_YIELD\_FLAG' set but not used [-Wunused-but-set-variable] Creating object file for ws2812.c i:/MIOS32/trunk/modules/ws2812/ws2812.c:71:2: warning: #warning "WS2812 driver not supported for this derivative yet!" [-Wcpp] i:/MIOS32/trunk/modules/ws2812/ws2812.c:102:12: warning: 'send\_buffer' defined but not used [-Wunused-variable] Creating object file for msc\_bot.c i:/MIOS32/trunk/modules/msd/LPC17xx/msc\_bot.c: In function 'MSCBotBulkOut': i:/MIOS32/trunk/modules/msd/LPC17xx/msc\_bot.c:268:13: warning: variable 'iChunk' set but not used [-Wunused-but-set-variable] Creating object file for msc\_scsi.c i:/MIOS32/trunk/modules/msd/LPC17xx/msc\_scsi.c: In function 'SCSIHandleCmd': i:/MIOS32/trunk/modules/msd/LPC17xx/msc\_scsi.c:155:14: warning: variable 'dwLBA' set but not used [-Wunused-but-set-variable] Creating object file for freertos\_heap.cpp c:/mios32\_toolchain/bin/../lib/gcc/arm-none-eabi/4.7.4/../../../../arm-none-eabi/bin/ld.exe: project\_build/project.elf section `.bss' will not fit in region `RAM' c:/mios32\_toolchain/bin/../lib/gcc/arm-none-eabi/4.7.4/../../../../arm-none-eabi/bin/ld.exe: region `RAM' overflowed by 672 bytes collect2.exe: error: ld returned 1 exit status make: \*\*\* [project\_build/project.elf] Error 1
Thanks, Marco.
It seems that your repository contains expired source files, this compile problem for LPC17 has been fixed some time ago.
Just update your subversion repository
I updated today, and the problem continues…
