hi
i am looking for a smart way to isolate panel mount parts in metal casing, i need to isolate a 3,5 mm power plug (as the one you get with a core)
simone
hi
simone
Safe way would be to buy plastic enclosed connectors, you may want to change from this:
to this
and
otherwise some ideas:
heat shrink tubing into the jack bushing with a couple of plastic washers on both sides?
alternatives to the heat shrink: teflon tape <- used this along with the plastic washers to mod my gt3 for 2 expression pedals.
you could try hot glue too, just cover the metal parts and cut out as needed to make it fit again. 8)
hi
yep sorry it wasn t really precise, they are not 3,5 mm, they are as those pictured below.The socket you show are not panel mount but i liked the shrinking tube idea i will go for that.I am only worried that the sharp edges of the hole could cut through the plastic and reach the metal of the socket.I ll let you know how it goes
tx
simone
just leave the holes nice and smooth to the tact to avoid any tubing damage, once the jack is mounted tightly it won’t go anywhere ![]()
hi there!
my power plug is “connected” with my metal case but i use a direct current adapter and set the outside of
the connector as minus. no problems so far. but is it recommended to isolate that from the case?
thanks!
gabriel
