Hi Mike,
There’s no “switch” or define for this.
It was made like this to match the old PIC DOUT pinout.
///////////////////////////////////////////////////////////////////////////// //! temporary help array to mirror a byte //! (could be provided as MIOS32 help function later) ///////////////////////////////////////////////////////////////////////////// // DOUT bits are uploaded in reversed order compared to PIC based MIOS, and // especially compared to the order on DIN registers // Most applications would have to convert this - therefore it's already done // by MIOS32\_DOUT\_\* functions // mirroring could work with: // u8 mirror\_u8(u8 b) // { return ((b&0x01)\<\<7) | ((b&0x02)\<\<5) | ((b&0x04)\<\<3) | ((b&0x08)\<\<1) | ((b&0x10)\>\>1) | ((b&0x20)\>\>3) | ((b&0x40)\>\>5) | ((b&0x80)\>\>7); } // bit this would be a bit slow, e.g. for SR copy routines - therefore we use a table based approached: // the table has been generated with: // perl -e 'for($b=0; $b\<256; ++$b) { printf("0x%02x,", (($b&0x01)\<\<7) | (($b&0x02)\<\<5) | (($b&0x04)\<\<3) | (($b&0x08)\<\<1) | (($b&0x10)\>\>1) | (($b&0x20)\>\>3) | (($b&0x40)\>\>5) | (($b&0x80)\>\>7)); }; printf("\n");' const u8 mios32\_dout\_reverse\_tab[256] = { 0x00,0x80,0x40,0xc0,0x20,0xa0,0x60,0xe0,0x10,0x90,0x50,0xd0,0x30,0xb0,0x70,0xf0, 0x08,0x88,0x48,0xc8,0x28,0xa8,0x68,0xe8,0x18,0x98,0x58,0xd8,0x38,0xb8,0x78,0xf8, 0x04,0x84,0x44,0xc4,0x24,0xa4,0x64,0xe4,0x14,0x94,0x54,0xd4,0x34,0xb4,0x74,0xf4, 0x0c,0x8c,0x4c,0xcc,0x2c,0xac,0x6c,0xec,0x1c,0x9c,0x5c,0xdc,0x3c,0xbc,0x7c,0xfc, 0x02,0x82,0x42,0xc2,0x22,0xa2,0x62,0xe2,0x12,0x92,0x52,0xd2,0x32,0xb2,0x72,0xf2, 0x0a,0x8a,0x4a,0xca,0x2a,0xaa,0x6a,0xea,0x1a,0x9a,0x5a,0xda,0x3a,0xba,0x7a,0xfa, 0x06,0x86,0x46,0xc6,0x26,0xa6,0x66,0xe6,0x16,0x96,0x56,0xd6,0x36,0xb6,0x76,0xf6, 0x0e,0x8e,0x4e,0xce,0x2e,0xae,0x6e,0xee,0x1e,0x9e,0x5e,0xde,0x3e,0xbe,0x7e,0xfe, 0x01,0x81,0x41,0xc1,0x21,0xa1,0x61,0xe1,0x11,0x91,0x51,0xd1,0x31,0xb1,0x71,0xf1, 0x09,0x89,0x49,0xc9,0x29,0xa9,0x69,0xe9,0x19,0x99,0x59,0xd9,0x39,0xb9,0x79,0xf9, 0x05,0x85,0x45,0xc5,0x25,0xa5,0x65,0xe5,0x15,0x95,0x55,0xd5,0x35,0xb5,0x75,0xf5, 0x0d,0x8d,0x4d,0xcd,0x2d,0xad,0x6d,0xed,0x1d,0x9d,0x5d,0xdd,0x3d,0xbd,0x7d,0xfd, 0x03,0x83,0x43,0xc3,0x23,0xa3,0x63,0xe3,0x13,0x93,0x53,0xd3,0x33,0xb3,0x73,0xf3, 0x0b,0x8b,0x4b,0xcb,0x2b,0xab,0x6b,0xeb,0x1b,0x9b,0x5b,0xdb,0x3b,0xbb,0x7b,0xfb, 0x07,0x87,0x47,0xc7,0x27,0xa7,0x67,0xe7,0x17,0x97,0x57,0xd7,0x37,0xb7,0x77,0xf7, 0x0f,0x8f,0x4f,0xcf,0x2f,0xaf,0x6f,0xef,0x1f,0x9f,0x5f,0xdf,0x3f,0xbf,0x7f,0xff };
This helper was not implemented. And the problem is that MIOS32_DOUT_SR_xx use this array but not the MIOS32_DOUT_Pin_xx
But you use the right method
except that it works only for pin 0 to 7.
If you want to do it on all the pins you have to include the SR number just implent something like this.
e.g.
u32 PIN\_REVERT(u32 pin) { u8 num\_sr = pin\>\>3;// divide by 8 pin %=8;// modulo by 8 return (u32)((num\_sr\<\<3) + (7-pin)); }
then use it:
MIOS32\_DOUT\_PinSet(PIN\_REVERT(pin), value);
