instead of pot value 0-127, value text
hi  ;D
midibox 64 lcd menu display normaly prints the pot name and the value 0-127. so far this works.
now i want to chance the number value to a text value, for example:
when i move pot #6 (midi cc#118)
for value 0-10 the display should print ES1, for value 11-22 the display should print ES2,
for value 11-22 the display should print EXS, for value 23-34 the display should print EVOC,  and so on..
where do i have to define this values, in mb64_lcd.inc ?
thanx for any help, its better to spend hours behind mios than watching tv for hours  :wink:
hi
Firstly please try with some paper on glue closer to knob with :
0-10 ES1
11-22 ES2…
and check it , try , play with it.
If you will see that this is not enough and you must to have this on LCD
then you can include a code who cathing your pot
(probubly in USER_AIN_notify…) and run your part who print texts depend from value.
hi qbas
i already made a text display in logic environment and played with it over 2years,
no i think its time to integrate it into my midi-box, just for feeling good  :wink:
first of all it would be alright to get the text values for all pots, i tried it in mb64_lcd.inc,
but it seems to be the wrong place, i’m searching the code which defines the numerical values.
any idea?
If you need 64 knobs with different texts you need define 64 tables of texts.
Please list all you wish and then we try help.
That seem like you tested your needings and you know what you want.
Thats great.
i just need for pot number 6 text values. i used a 12-way rotary pot, every single way is 10k
any idea where to to manage the value tables?
yes, i’m happy with my controller, use it for logic pro 7.1 and for live vj’ing.
if anyone wants .dwg files of the case, pm me… 8)
before start go inside code of MB64 firstly I would like to ask you that is this must be MB64?
or maybe is enough simpler program where pots only send CC from 0-63 with values 0-127?
it dont have to be mb64, i used it because its easy to programm, leds work, knobs toggle…
but i need full cc# range!
see files for more information:
http://magdesign.ch/Files/MIOS/MultiControlProT.JPG
http://magdesign.ch/Files/MIOS/Controllerzuweisung_Rev.A.pdf
thanks so far.
I can try find this for you in code, but it will come not too fast, if ever come.
no hurry, thanx anyway
if just someone could tell me how to define the value ???
its maybe in
mb64_lcd
MB64_LCD_PrintValue
andlw 0x03
JUMPTABLE_2BYTES 4
rgoto MB64_LCD_PrintValue_Hex
rgoto MB64_LCD_PrintValue_PmHex
rgoto MB64_LCD_PrintValue_Dec
rgoto MB64_LCD_PrintValue_PmDec
;; print hex value 0x00..0x7f
movlw ’ ’ ; fill with space
call MIOS_LCD_PrintChar
movf INDF0, W
andlw 0x7f
goto MIOS_LCD_PrintHex2
hope to find a solution…
mios rocks!
Hello Thorsten Klose.
Before we will try changing something can we ask you what is the best direction for achieve in MB64 this:
Thank you
OK, I’m not TK, but I’ll take a shot at this.
This may not be the best way, but it will work.
So I’m guessing you have about twelve choices.
The first step is to convert your 0-127 input into 0-11 for your twelve choices.
We take your original value and divide by about 10.66. Since division is
not easy, we’ll multiply by 24, then divide by 256.(both easy to do)
movf  yourvalue,W   ;get your starting value
mullw d’24’
movf  PRODH,W    ;now you have 0-11 in W
call channame    ;selects the right name
call MIOS_LCD_PrintString ;and prints it
Next up is to choose your label. I’m SURE there are better ways, but
this works for me.
;this will select the proper name for a given channel (in W)
channame
movwf NameScan ;store our channel target
TABLE_ADDR TEXT_CHAN_0 ;point to first name
movf  NameScan,F
btfsc STATUS,Z ;if the channel number is Zero,
return
TABLE_ADDR TEXT_CHAN_1 ;point to second name
dcfsnz ChanScan ;decrement the channel number. If the result is zero,
return
TABLE_ADDR TEXT_CHAN_2 ;point to the third name
dcfsnz ChanScan ;dec the channel number. If the result is zero,
return
TABLE_ADDR TEXT_CHAN_3 ;point to the fourth name
dcfsnz ChanScan ;dec the channel number. If the result is Zero,
return
TABLE_ADDR TEXT_CHAN_4
dcfsnz ChanScan ;repeat until a name is found
return
TABLE_ADDR TEXT_CHAN_5
dcfsnz ChanScan
return
TABLE_ADDR TEXT_CHAN_6
dcfsnz ChanScan
return
TABLE_ADDR TEXT_CHAN_7
dcfsnz ChanScan
return
TABLE_ADDR TEXT_CHAN_8
dcfsnz ChanScan
return
TABLE_ADDR TEXT_CHAN_9
dcfsnz ChanScan
return
TABLE_ADDR TEXT_CHAN_10
dcfsnz ChanScan
return
TABLE_ADDR TEXT_CHAN_11
return
Finally, define the names with the string macro
;Name your channels here
;remember to change the number to the length of the new name
;the 0x04 tells where to put the text on the display
TEXT_CHAN_0 STRING 8,0x04,“Whatever”
TEXT_CHAN_1 STRING 3,0x04,“XVQ”
TEXT_CHAN_2 STRING 3,0x04,“FU2”
TEXT_CHAN_3 STRING 9,0x04,“Channel 4”
TEXT_CHAN_4 STRING 9,0x04,“Channel 5”
TEXT_CHAN_5 STRING 9,0x04,“Channel 6”
TEXT_CHAN_6 STRING 9,0x04,“Channel 7”
TEXT_CHAN_7 STRING 9,0x04,“Channel 8”
TEXT_CHAN_8 STRING 9,0x04,“Channel 9”
TEXT_CHAN_9 STRING 10,0x04,“Channel 10”
TEXT_CHAN_10 STRING 10,0x04,“Channel 11”
TEXT_CHAN_11 STRING 10,0x04,“Channel 12”
Hope that helps,
LyleHaze
[edit] cleaned up the code just a little bit
hi Lylehaze!
great job, but where is the point in MB64 code for putting execute of display this?
Gee, I don’t know.
I’ve been so busy with my own code, I’ve not yet had a chance to look at the MB64 code.
The OP said it was already displaying a value, so maybe
find that display code and replace it with a call to the above?
I would _hope_ that the original poster was seeking to learn a technique, instead of just finding someone to do it for him… But I don’t know. :slight_smile:
In any case, the code will work, but It’s most definetly not the best way to do this. Maybe someone will volunteer a better way.
Good Luck,
LyleHaze
