Hi guys,
Ive had a root around the components in my electronics deparment and managed to find some IC’s for use in the AIN and DIN board. Would it be OK to replace, the CD 4051 BE multiplexer in the AIN board with a cd 4051 BCN? As regards to the DIN board, could I replace the 74HC165 shift register with DM74LS165N? Links to the data sheets are below:
74HC165
I can see some difference in operating voltages, but without knowing what voltages are used in the boards, I cant see whether theyll work? Also if anyone can see of any other reason why using these chips won’t work, give me a shout.
Kind Regards,
Harry
