Hello,
How can I change the LSB / MSB order of DOUT Modules in mios_srio.inc
chris
Hello,
chris
Here the required modification:
MIOS_SRIO_Loop
btfsc MIOS_SRIO_PORT_DIN, MIOS_SRIO_PIN_DIN
bsf IRQ_TMP5, 7
bsf MIOS_SRIO_LAT_DOUT, MIOS_SRIO_PIN_DOUT
btfss INDF2, 7
bcf MIOS_SRIO_LAT_DOUT, MIOS_SRIO_PIN_DOUT
btfss MIOS_SRIO_PORT_DIN, MIOS_SRIO_PIN_DIN
bcf IRQ_TMP5, 7
bsf MIOS_SRIO_LAT_SCLK, MIOS_SRIO_PIN_SCLK
nop
bsf IRQ_TMP5, 6
bcf MIOS_SRIO_LAT_SCLK, MIOS_SRIO_PIN_SCLK
btfss INDF2, 6
bcf IRQ_TMP5, 6
nop
bsf IRQ_TMP5, 5
btfss INDF2, 5
bcf IRQ_TMP5, 5
nop
bsf IRQ_TMP5, 4
btfss INDF2, 4
bcf IRQ_TMP5, 4
nop
bsf IRQ_TMP5, 3
btfss INDF2, 3
bcf IRQ_TMP5, 3
nop
bsf IRQ_TMP5, 2
btfss INDF2, 2
bcf IRQ_TMP5, 2
nop
bsf IRQ_TMP5, 1
btfss INDF2, 1
bcf IRQ_TMP5, 1
nop
bsf IRQ_TMP5, 0
btfss INDF2, 0
bcf IRQ_TMP5, 0
nop
[/code]
and attached a precompiled .hex file
[mios\_p18f452.hex](< ___base_url___ >/applications/core/interface/file/attachment.php?id=6965)
Sorry,
I tried that yesterday without success, but I am not sure.
I test it with dout_buttons_v1c application and the result is the same as with unmodified mios_srio.inc
SR# 1 Pin#0 0x00 let lit a LED on physical Pin 7 (QH) on a 74HC595
SR# 1 Pin#7 0x07 let lit a LED on physical Pin 15 (QA) on a 74HC595
that are the right results for standard mios_srio.inc I guess.
but I get this for both cases modified and unmodified.
I have also tried to change the DIN bit order with same effect.
It seems that nothing changes.
What about the applications, are there any changes to make?
chris
So, you compiled MIOS by yourself and uploaded it to your core before uploading the application?
If this modification hasn’t caused an effect, then I assume an handling error (please describe more exactly what you did to clarify the issue).
Since I assume an handling error, I attached a precompiled .hex file so that you can easily compare the results.
Before continuing with speculations, could you please give me some feedback if the .hex file I gave you is working at your side.
There are no other changes which are required, it’s really straightforward.
Yeah,
I wondered by myself but the precompiled Mios Version do the same.
I have also think about a upload failure, but the precompiled Version shows no longer the “READY.” Message first.
And so I think all is gone right by uploading.
I will now have a try with Linux and MIOS Studio 9 to upload, because I can’t use the core feedback feature with my old Win 98 ![]()
and Studio 7.5
Later more …
Chris
and Studio 7.5
Later more …
Shit I can’t believe that.
I’m so sorry
Yes it works, now.
MIOS wasn’t uploaded right to the core, I don’t know why.
Most changes (try to learn assembler the last days :D) on MIOS or MB64 takes a small effect and I thought the code was proper uploaded to the core.
Thanks for the help Thorsten and best wishes for the coming decade.
Chris
