How many encoders can you have?
I’ve looked on the forums and the wiki, but couldn’t find an answer to this question. (Direct answers or pointers to the info I missed are both welcome, thanks)
How complex a control surface can you make with the midibox SID? For example, could I break it out so I had discrete controls for each of the three oscillators if I wanted to? Or is the MB6582 kit essentially the extent of the control surface you can support. I’m sitting here looking at my JP-8080 thinking it would be wonderful to have something that rich for the SID.
What’s the limiting factor?
Thanks.
Pete
There’s no limiting factor really. If you’re willing to use another core module for instance (possibly with a bit of extra software) you can essentially make it as complex as you want. With the current setup the limiting factor would either be the software (there’s not a lot of room left for extensions on the PIC) or the number of DIN/DOUT ports supported by MIOS.
