help with relay control
[MIDI_IN]
Output Pin 1-4 assigned to Channel 1
   1 =  C0 00
   2 =  C0 01
   3 =  C0 02
   4 =  C0 03
Does the above mean that when I send the control change message  00 that pin 1 will be active?
Now if I alter the above to
[MIDI_IN]
   1 =  C0  90 3C 47
  that when the note middle c is played on channel 1 that pin one will be active? or is there more code needed? and how do I get the pin to turn off once its on? thanks for holding my hand.
anyone?
See http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=troubleshooting;action=display;num=1097358846
Please don’t spread the questions to a certain issue over different articles, it makes it impossible for us to gather all informations about a problem, and it makes the maintenance of this forum difficult.
